Wil my ae86 tranny work with a 2jzge engine?
Faz707
Postby Faz707 » Fri Feb 21, 2014 7:09 pm
Looking to buy 2jzge and was wondering if my stock 5 speed tranny would work with it or if I may need to get a new one.
Also if not what engine would you recommend for a legal swap.
Thank you
meifert
Re: Wil my ae86 tranny work with a 2jzge engine?
Postby meifert » Fri Feb 21, 2014 10:04 pm
I dont think the engine will fit in the car. Its probably too long.
1984 Corolla SR5.....banana on wheels
Buddy Club Spec 2 Over axle, T3 Test Pipe, T3 Bomber Bar, T3 Ultimate Rear Brace, Enkei Apache 2 wheels, (Weber carb and Cam not installed)
Cheap, good or fast.....pick two.
Postby jondee86 » Fri Feb 21, 2014 10:31 pm
Faz707 wrote:Looking to buy 2jzge and was wondering if my stock 5 speed tranny
Engine will fit, it has been done many times. Tranny will last
until the first time you dump the clutch. You need to look for
a W-Series gearbox, and a Celica or HiLux rear end.
Jeff Lange
Postby Jeff Lange » Sat Feb 22, 2014 7:48 am
No, it won't.
Use a W58 (which came on the 2JZ-GE).
Jeff
ra40
Postby ra40 » Sat Mar 01, 2014 6:15 pm
t50 wasnt designed for that kind of power, it barely handles a modded 20valve... w58 will hold up. stock rear end wont hold up either fyi
