Please Delete
TheOxyMorin
Please Delete
Postby TheOxyMorin » Sun Jun 30, 2013 6:06 pm
Hey all,
I purchased a Blacktop 20v for my AE86 hatch a few months ago. I have a distributor relocation kit and water cooling kit for it...
But the thing on my mind as my biggest concern now is the wiring. I have all the wiring for the car as well as the 20v wiring harness and ECU.
What am I looking at as my biggest speed bump in my build at this point?
Any advice or information would be greatly appreciated.
Thank you for your time!
stalk86
Re: Need AE86 20v Swap Wiring Harness Info
Postby stalk86 » Mon Jul 01, 2013 3:14 pm
Tweak'd Performance will make you a new one for $500 http://www.tweakdperformance.com/index2.html
Or you can make your own following Morgan's write up or others. http://forums.club4ag.com/zerothread?id=101899
morgan
Postby morgan » Tue Jul 02, 2013 9:28 am
everything is a speed bumb without the proper research prior to starting. my write-up that stalk provided will help, but theres a lot left for you to figure out.
My turd of an 86
20v swapped 86 write-up
TheOxyMorin
Postby TheOxyMorin » Thu Jul 04, 2013 3:24 pm
stalk86 wrote:Tweak'd Performance will make you a new one for $500 http://www.tweakdperformance.com/index2.html
I'm competent in reading and repairing wiring harnesses, connectors, etc... $500 dollars for what? I'm running the distributor and stock ECU... is there really much more I need? NO COP or aftermarket ECU...
TheOxyMorin
Postby TheOxyMorin » Thu Jul 04, 2013 3:27 pm
morgan wrote:everything is a speed bumb without the proper research prior to starting. my write-up that stalk provided will help, but theres a lot left for you to figure out.
My engine is in good running condition fresh from Japan... I read a lot on your write-up to prepare myself. Running SQ Engineering parts for ignition and cooling but I'm not sure what else I have to do to either the 16v or 20v harnesses before they're ready to be dropped in. Thanks for you write-up btw much appreciated.
morgan
Postby morgan » Sat Jul 06, 2013 10:09 am
You need to merge the 2. I've done 2 like that for friends, it takes some time, not as easy as you would hope. If you're good with wiring and diagrams you should be able to figure it out with my write-up
My turd of an 86
TheOxyMorin
Postby TheOxyMorin » Sat Aug 31, 2013 9:12 pm
morgan wrote:You need to merge the 2. I've done 2 like that for friends, it takes some time, not as easy as you would hope. If you're good with wiring and diagrams you should be able to figure it out with my write-up
I understand to a degree... but the write-ups don't explain to a degree before they start showing tons of photos. For example: What do I actually have to wire myself... it's frustrating.
