coolant sensors???
jerry7784
coolant sensors???
Postby jerry7784 » Tue Apr 09, 2013 7:26 pm
Hi guys just picked up a 85 corolla with a 4ac engine. anyways can you guys tell me what these to sensors are on the top??? thanks
jerry7784
Re: coolant sensors???
Postby jerry7784 » Tue Apr 09, 2013 9:43 pm
anybody????
phanist
Postby phanist » Thu Apr 11, 2013 3:47 am
hmmm i dont know because i never see or have an 4ac motor before.. but i bet if u pull those off and run to the junkyard and look at an 1980 and up toyota... look for it around those water outlet rear and front..
if u find the same size sensor it should work for u.. it my guess...
i think the smaller sensor to left is maybe a 17mm socket and the right side is 19mm .. take it off and find one to replace them at the Jyard.. and plug them in .. as for which plug is for what.. im guessing water temp. for gauge ..
PHiSH
Postby PHiSH » Wed Apr 17, 2013 10:45 am
I'm not sure if you still need the answer, but the red one on the left is the temperature detect switch and is part number 89427-16020. The right is the thermostatic vacuum switching valve (TVSV) and the part number is 90925-02076. I know the TVSV is still available at Toyota and is something like $140. I just had to replace it in one of my Corollas.
