Fuel line filter question
Shuwey
Postby Shuwey » Mon Apr 01, 2013 2:49 pm
When I was removing the stock Fuel filter from my 1985 corolla gts I accidently bended the fuel line really bad so I just decided to rip it off.
Can someone tell me where I can buy a new one, or does the 1985 MR2 have the same line?
Any help will be appreciated, thanks!
ga_goosh
Re: Fuel line filter question
Postby ga_goosh » Mon Apr 01, 2013 2:53 pm
you can get a line flaring tool at your local parts store. i would get some fuel hard line and practice flaring some spare line. once you feel comfortable give it a try on the car. you might have to make an extention since you broke the old line. if you want a stock line then start hunting the yards. im sure the mr2 will not fit since the engine is in the rear and has different routing bends.
I <3 my AE86
4AG Manual
AE86 FSM
Shuwey
Postby Shuwey » Mon Apr 01, 2013 4:41 pm
ga_goosh wrote:you can get a line flaring tool at your local parts store. i would get some fuel hard line and practice flaring some spare line. once you feel comfortable give it a try on the car. you might have to make an extention since you broke the old line. if you want a stock line then start hunting the yards. im sure the mr2 will not fit since the engine is in the rear and has different routing bends.
would I have to replace the whole line, or can i just attach another tip? (if toyota still sells them)
LongGrain
Postby LongGrain » Mon Apr 01, 2013 8:00 pm
like he said, you can cut the end of the line clean, put a tube nut on there and re flare it if you want.
if you dont want to do that you need a whole new line.
