Standalone harness
84Hachi17
Standalone harness
Postby 84Hachi17 » Wed Mar 20, 2013 5:45 pm
I'm looking into buying a haltech sprint 500 to run my 20v since I have a 84 hachi I would need to buy a gts body harness and all that junk. I've only found info on the haltech EMS and the hear the megasquirt is horrible. Anyone have any other suggestions?
gotzoom?
Re: Standalone harness
Postby gotzoom? » Thu Mar 21, 2013 8:51 am
There's nothing horrible about Megasquirt other than the people that buy them because they are cheap and then expect it to work like a stock ecu. :) You should be able to find a chopped up stock harness pretty easily. If you do that, just make your own harness. It's not that hard to do if you take your time and plan things out.
Russ
Postby Russ » Fri Mar 22, 2013 6:02 am
Plus most people's experience with MS was with MS1 five years ago. Just because MS1 was first and is least expensive does not mean it is the easiest to use or best choice, in my opinion it's exactly the opposite. MS2 and MS3 are completely different and much more user friendly. Plus if you want it to run like stock or better, it's all in the tune, almost nothing to do with the hardware. An un-tuned Haltech will run just as good as an un-tuned MegaSquirt.
If you go with a programmable ECU, no matter what brand, make plans to visit a dyno. It is beyond me why anyone would purchase a programamble ECU so they can tune the engine for their modifications, but then never take it to a dyno to get it tuned and then bash the hardware / brand name when that's not the issue at all.
Call around to your local dyno shops and see what systems they are familiar with, that would be the best system for you to consider. If you find a shop that will tune a MegaSquit then your engine can run as good as with any other ECU but only as good as the tuner's ability, only for a fraction of the hardware cost. MS has evolved to the point with MS2 and MS3 where those that consider it a joke and only a hobby kit need to take another look.
http://www.diyautotune.com/racing/drag_week_2011_results.htm
Many shops like to sell a particular brand of ECU and turn away the rest if you don't buy their product. Think about this, if you can tune a fuel table and ignition table, you can tune a fuel table and ignition table. Greedy shop owners will turn away a simple tune job because they're not selling you a multi-thousand dollar ECU and install job along with the $75/hour tune (or whatever their hourly rate is).
I run a MicroSquirt (MS2) based system on my engine and I don't care if someone gave me a Haltech, Motec, or one of the McLaren Nascar/F1 ECUs, I wouldn't trade my MS for anything. Remember it's all in the tune. I run a 16V with ITBs and LS1 coils, sequential fuel and ignition operation, individual cylinder fuel trims, reading RPM from a DLI GZE cam angle sensor unit in place of the distributor.
http://www.diyautotune.com/russ/itb-with-ls.jpg
Yes I do work for DIYAutoTune so view my bias as you will. I'm here to offer help and support should you need it. If you have any questions about MS or if I've made you raise an eyebrow, don't hesitate to give me a shout websales@diyautotune.com and my name is Russ.
84Hachi17
Postby 84Hachi17 » Fri Apr 12, 2013 10:14 pm
Russ wrote:Plus most people's experience with MS was with MS1 five years ago. Just because MS1 was first and is least expensive does not mean it is the easiest to use or best choice, in my opinion it's exactly the opposite. MS2 and MS3 are completely different and much more user friendly. Plus if you want it to run like stock or better, it's all in the tune, almost nothing to do with the hardware. An un-tuned Haltech will run just as good as an un-tuned MegaSquirt.
Thanks for the information, i really took a wrong look at megasquirt, bias or not still very helpful appreciate it.
Russ
Postby Russ » Mon Apr 15, 2013 5:04 am
No problem! Is it a stock 20V in an 84 SR5 chassis? I've always wanted to check out a 20V but I haven't had a good chance yet.
