Hi everyone! Just wanted to ask what the best wheel size, offset, and disk type to select from for a set of work equip 03s. I would be running just shocks and springs, so no major modifications to suspension or body.
I didn’t know if the T3 baby daddy kit in the front would cause problems for the work wheels, and if not, then which is the right type to get (a disk, o disk). Also, does anyone know if I get the rear big brake kit from T3, what would be the best on that?
Thank you all in advance!
Work Equip 03 + T3 baby daddy brake kit
- idreamofdrifting
Re: Work Equip 03 + T3 baby daddy brake kit
what engine do you have that would justify you running a bbk?
idreamofdrifting wrote:what engine do you have that would justify you running a bbk?
Just the regular 4AG, but it already has the T3 kit so that’s why I was asking. Not for the rear though.
If you contact T3 they can send you a wheel fitment template for that kit. I have the big daddy brake kit from T3 and it will fit 15x8 0 offset just fine. Since you have the baby version, you probably have more options when it comes to offsets and sizes.
A worn out low compression stock one?
Nick94tt wrote:idreamofdrifting wrote:what engine do you have that would justify you running a bbk?
that very same one
Wondering the same with CR-01 15" and the older wilwood 4pots. Would like to order o-disk but worried it will hit the caliper.
Wish Work offered this information on their website. The chart only shows lip size. I am waiting to hear back from them.
