Levin Hood Issue
Gabriel82
Levin Hood Issue
Postby Gabriel82 » Mon Jul 15, 2019 8:17 pm
Hi everyone,
I recently got my hands on a levin hood. I'm trying to mount it and it looks like my chassis has a hook welded to the body that grooves into the oem trueno hood? Does this need to be chopped off?
Gabriel82
Re: Levin Hood Issue
Postby Gabriel82 » Mon Jul 15, 2019 8:37 pm
Or are levin hood hinges different?
kiosk
Postby kiosk » Mon Jul 15, 2019 10:02 pm
Assuming you have everything it should be a straight swap. have a picture to see what you're talking about?
Gabriel82
Postby Gabriel82 » Tue Jul 23, 2019 2:24 pm
Kiosk - you were right. It was a two man job lining it up but it fit and stopped making contact with that stopper/hook looking thing.
Postby jondee86 » Wed Jul 24, 2019 4:34 am
FWIW those hook things are there to help stop the hood coming thru the windscreen
and cutting your hair when you have a decent frontal impact :)
morgan
Postby morgan » Fri Jul 26, 2019 5:02 am
not all aftermarket hoods have the holes cut. youre supposed to cut a hole in the hood, to match the oem hood, so the hook can go in.
My turd of an 86
20v swapped 86 write-up
