I own a 3sge swapped 86 with a oem GTS differential using T3 clutch packs, I recently broke something internally in my diff making a slow U-turn.
From looking at the diff with it out of the car, it looks like a rock bounced around inside the casing leaving gashes on parts of the diff. all the gaears have all there teeth and the oil and magnet did not have large shavings but there was definitely some metal. The gears now have play and when I moved the car into my garage to remove the differential the diff acted like it was welded making both tires lock together.
I was looking at new LSD options but with the added power I feel i'm going to need a reinforced ring gear and input shaft gear (don't really know what anything is called) along with upgraded axles. I saw a kit from Weir that looked right but it's also 1000$ not including the LSD it self and they look like they have not stocked the part in years. http://www.weirperformance.com/axlekits ... erear.html
I am just looking for a way to build the GTS rear end without a swap from another car like the ford 8.8 or the supra swap and hold at the very least 230 hp
If anyone can help me figure this out i would really appreciate it.
