Sorry for basically re posting since this was posted like 1000 times on the old forum but I'd appreciate any advice or help!
Red wrote:Ryuesi, you can't just "drop" a bluetop into an SR5. You also need a different fuel tank, fuel lines, plumbing for the two, fuel pump, complete and MATCHING ignitor and ECU, harness wiring...maybe you remember the old forum had links to a 2-part magazine article that went through everything that had to be done. It is NOT "drop in". It is not cheap or simple. And when you are done, you will have thrown away a lot of the money because "FrankenCars" don't make it back on resale.
Better to look at the options for what you have, folks have modified the 4AC engine to produce just as much power as the 4AGE, and you can modify everything else with equally effective results. Drop in a Bilstein suspension if you want something better than GT-S. Check around, there's plenty to do that will make your car just as fast, just as sweet, without all the headaches of a FrankenCar.
Red wrote:If you go to achive.org, aka "the wayback machine" you can poke around in the archived copy of the old forum message base. Look for the faq and tech ref sections, or look on the web for an Ozzie named "Bill Sherwood" who posted a lof of info on his own web sites. You should be able to find out what can be done to a 4AC to give it 4AGE power.
Brakes? First I'd work on power, you don't need more brakes until after you've got more speed and if you've had stopping problems.<G> Of course that will need a complete GT-S drivetrain donor, everything from the prop shaft back to the wheels has to change. So keep an eye out for those donor cars in the meantime.
Also check into whatever the rules are for the organizing bpody that will be conducting the races. They all have rules about modifications and classes, and if you change the wrong piece of equipment, you get bumped into a much more competitive class which might eat you alive. Others may let you run with any modifications you please, so "just" doing the cams, shaft, compression, and a blower might work. Folks who are already racing in that group may be very willing to chat with you and tell you what they're running. Sometimes they'll just smile and not say anything, but often they'll tell you what is working, or not. So hanging at the track, great resource too. Easy way to make new friends: Go on a really hot day, and pass out some extra cold water bottles, or something better.<G>
