The part # of the pinion and the crown ring of the ae86 is "41201-29207"
Does anyone knows if the ratios starting with 41201 part no. ( rav4 , hiace , landcruizer etc.) are interchangeable with my stock. ?
Sent from my SM-G900F using Tapatalk
Ae86 - Diff ratio
Re: Ae86 - Diff ratio
The following link shows the compatible oem part numbers:
http://club4ag.com/tech-data/tech-specs ... t-numbers/
hachirokkos
Thanks for the link.
As i can see from there as well, all the part numbers start with 41201. But the there are some other ratios that start with the same no. But are not listed there, like 4.9 or so
hachirokkos
Any1 ?
If you sift through the T-Series part numbers in this list...
http://members.iinet.com.au/~stepho/diff.htm#sets
... you might find what you are looking for
hachirokkos
Are all these interchangeable ?
All Toyota ring gears of the same size or letter code are interchangeable as long
as the matching pinion gear is swapped at the same time
So if it says that the vehicle was fitted with a T-Series differential, the CW&P
should be interchangeable with any other T-Series differential.
hachirokkos
jondee86 wrote:All Toyota ring gears of the same size or letter code are interchangeable as long
Thanks mate.
I appreciate that [emoji1]
