Help needed!!! Kouki SR5 rear disc conversion
jdv824
Postby jdv824 » Sun Oct 04, 2015 6:07 pm
I've been looking and can't find anything. Want to convert my car to rear disc. I know that it's easier to replace the whole dif but my car is an automatic and base on what I read I can't put a manual dif with a automatic transmission. I got the GT-S calipers already but don't know if I can do the conversion without replacing the whole dif.
83toywagonblue
Re: Help needed!!! Kouki SR5 rear disc conversion
Postby 83toywagonblue » Tue Oct 06, 2015 2:34 pm
Sent from my SM-N910T using Tapatalk
83toywagonblue
Hope that helps
jdv824
Postby jdv824 » Tue Oct 06, 2015 6:09 pm
Thank you just checked for prices and it's not that expensive. The only thing is not having a e brake. My car is an automatic and I park it on the driveway so jumping from P to D it's going to damage the tranny. Know this from past experience
gene4ace
Postby gene4ace » Wed Oct 07, 2015 7:53 am
I'm in SoCal and I have a complete gts rear end, non lsd, pm me.
jdv824
Postby jdv824 » Thu Oct 15, 2015 1:03 pm
Does anyone knows how to add e brake calipers for this set up?
Rogue-AE95
Postby Rogue-AE95 » Fri Oct 16, 2015 3:53 am
A while back I had asked about rear disc conversions...
viewtopic.php?f=9&t=4320
I still haven't gotten around to doing anything yet. I'll probably need something custom due to wanting to keep e-brakes.
jdv824
Postby jdv824 » Fri Oct 16, 2015 10:13 am
I wonder if you can install gts backing plates and put the calipers and rotors but I don't think it's going to be that easy.
Rogue-AE95 wrote:A while back I had asked about rear disc conversions...
Rogue-AE95
Postby Rogue-AE95 » Fri Oct 16, 2015 3:48 pm
The flanges on the GTS and SR5 housings have different bolt patterns. The GTS backing plates won't bolt right up to an SR5 axle without modification.
Postby jondee86 » Fri Oct 16, 2015 4:11 pm
jdv824 wrote:I've been looking and can't find anything. Want to convert my car to rear
I'm not going to say that you shouldn't convert a SR5 rear end to discs, but I am
wondering if all the effort is really going to be worth the end result ? Most of the
braking is done by the front wheels that already have discs. The factory designed
the braking system to be safe and balanced with discs in front and drums in back,
and you can have handling issues if you change the front-rear braking bias.
If you are still running the SR5 engine with an auto, I'd suggest that you look into
getting some new drums (or get the old ones skimmed) and a new set of shoes.
That might give you all the braking you need at the moment, and you can keep
an eye out for a complete GTS rear end to install when you upgrade the engine
and change to a manual gearbox.
jdv824
Postby jdv824 » Tue Oct 20, 2015 7:19 pm
Thank you guys for your input. I think I'm going to keep it his way then.
