Day 1 it had a high idle. messed with the carburetor and ignition timing a little bit and got it idling and running great. Even managed to get a couple donuts in my work's parking lot before a manager came out
![Laughing :lol:](./images/smilies/icon_lol.gif)
Day 2 I go to recheck everything and make sure it's ready to be registered and drivable. However that wasn't the case. Ran horrible, had no power, and smelt alot of fuel. Pulled each spark plug wire and found cylinder 1 was not firing in any way. As in absolutely no change in rpms.
Here's where it gets weird. I checked compression, I have 150 across the board. Fuel, well I can smell it, see it, and when I cranked it with the spark plug out I tasted it (best to not put your face right into the opening). From flooding cylinder 1 my oil seems like its 90% gas. Swapped spark plugs and wires around with no change. I determined it has to be the cap and rotor, because anything before that would cause a multiple misfire, not just one specific cylinder.
Cap and rotor did nothing. Same issue. Pulled valve cover and verified valves opening and closing. Checked and confirmed valve clearance was in spec. i was thinking perhaps exhaust runner plugged? Pulled off EGR tube (which connects to number 1 runner) and ran it. Still same issue.
I'm at a point where it has to be something stupid with these engines, that hopefully someone has run across? This car is supposed to be my daily, and it's been making me regret buying it every since. Help me out PLEASE if you know anything.
