JSP Formula Drift AE86 rebuild
tchybrid
Re: JSP Formula Drift AE86 rebuild
Postby tchybrid » Tue Nov 05, 2013 7:46 pm
Very sick John, can't wait to see that beast run!
boosted86
Postby boosted86 » Wed Nov 06, 2013 5:41 pm
Top notch as always!
john russakoff
Postby john russakoff » Thu Nov 07, 2013 9:21 am
Brakes are blead, trying to finish the wiring today. Hopefully running this weekend and dyno next week.
JSPfab
2588 progress #3
Vista CA 92081
John@jspfab.com
john russakoff
Postby john russakoff » Thu Nov 14, 2013 2:23 am
Ready for the dyno tomorrow. Antilag seems to work haha.
JSPfab
2588 progress #3
Vista CA 92081
John@jspfab.com
john russakoff
Postby john russakoff » Fri Nov 15, 2013 6:26 pm
base tune, stock engine. Time to go testing and start putting together a built block.
JSPfab
2588 progress #3
Vista CA 92081
John@jspfab.com
joel23
Postby joel23 » Fri Nov 15, 2013 8:34 pm
looks good.. and nice numbers... in for some vids.... :mrgreen:
john russakoff
Postby john russakoff » Sat Nov 23, 2013 2:15 pm
Headed to the track this weekend. Made all new windows. Mounted and programmed the racepak. Wired all the light. Buttoned up most of the inside. Made a couple test passes in front of the shop and found both rear lower links to be bent. I believe welding them softened the metal a ton. Im going to remake them in steel this week. Besides that everything else on the car has performed perfectly. Ill post up track video next weekend if it doesnt rain.
JSPfab
2588 progress #3
Vista CA 92081
John@jspfab.com
john russakoff
Postby john russakoff » Mon Nov 25, 2013 6:07 pm
Finally put the rear bumper haha.
JSPfab
2588 progress #3
Vista CA 92081
John@jspfab.com
alavelle12
Postby alavelle12 » Mon Nov 25, 2013 7:03 pm
haha finally what i was waiting for! jk, your build looks fantastic sir. one question i have though, why have a hydraulic e-brake if its a drag not a drift setup?
yellowsnow4free
Postby yellowsnow4free » Tue Nov 26, 2013 11:48 am
john russakoff wrote:Finally put the rear bumper haha.
Looks great! :D
How did you end up attaching the rear bumper?
I'm assuming you made some brackets to attach it, but in the previous pics it looks like all of the original mounting points were cut off :P
john russakoff
Postby john russakoff » Tue Nov 26, 2013 7:54 pm
Yeah made brackets.
JSPfab
2588 progress #3
Vista CA 92081
John@jspfab.com
john russakoff
Postby john russakoff » Fri Nov 29, 2013 1:57 pm
figured it would be smarter to remake the upper links while I was at it. These arms are rediculous. They probably weigh at least 8lbs a side.
JSPfab
2588 progress #3
Vista CA 92081
John@jspfab.com
john russakoff
Postby john russakoff » Fri Nov 29, 2013 2:00 pm
Rear bumper mount for who asked
JSPfab
2588 progress #3
Vista CA 92081
John@jspfab.com
sekang0
Postby sekang0 » Fri Nov 29, 2013 8:48 pm
daaaaaaaamn! too amazing.
'85 GT-S project since 2010
john russakoff
Postby john russakoff » Sun Dec 01, 2013 5:25 am
6.6@112 1.48 60ft
prob around a 10.0-10.2 1/4
I was having trouble keeping the turbo under boost from 1-2. It really needs more boost to function properly.
JSPfab
2588 progress #3
Vista CA 92081
John@jspfab.com
carbd7age
Postby carbd7age » Sun Dec 01, 2013 11:36 am
Dadgum if you bend those new rear arms, you did something wrong! Looks great John. What would you do to solve the boost issue, just run a bigger turbo?
Knockoff Crew member #0001
john russakoff
Postby john russakoff » Sun Dec 01, 2013 3:52 pm
No, turbo is too big for the power im making now. It will be fine once the built engine is put in and running more boost. Only 20psi right now. This turbo is barely spinning so looses speed easily. This turbo is designed to run 40-60psi.
JSPfab
2588 progress #3
Vista CA 92081
John@jspfab.com
carbd7age
Postby carbd7age » Mon Dec 02, 2013 5:51 am
Crap it's already making 600whp, what will it hit with the built engine? 8-900?
john russakoff
Postby john russakoff » Mon Dec 02, 2013 7:27 am
Goal is 1100+
JSPfab
2588 progress #3
Vista CA 92081
John@jspfab.com
Clouds
Postby Clouds » Mon Dec 02, 2013 8:40 am
john russakoff wrote:Goal is 1100+
1,100? What would the horsepower per ton be?
carbd7age
Postby carbd7age » Mon Dec 02, 2013 6:26 pm
Bugatti power from Honda guts in a Toyota shell.....
john russakoff
Postby john russakoff » Tue Dec 03, 2013 9:43 am
1100hp = 1 ton of hp = hauling ass
pretty sure I did the math right on that.
JSPfab
2588 progress #3
Vista CA 92081
John@jspfab.com
john russakoff
Postby john russakoff » Wed Dec 18, 2013 10:43 pm
Sideskirts and lip on. More 1/8 mile testing friday.
JSPfab
2588 progress #3
Vista CA 92081
John@jspfab.com
john russakoff
Postby john russakoff » Thu Dec 19, 2013 8:07 pm
Last two in the rain today. Dyno again tomorrow to turn it up a little and set up traction control and data logging. Then testing tomorrow night if no rain.
JSPfab
2588 progress #3
Vista CA 92081
John@jspfab.com
joel23
Postby joel23 » Fri Dec 20, 2013 12:28 pm
looks great man... :mrgreen:
crazyae86
Postby crazyae86 » Tue Dec 24, 2013 5:30 am
hi there i read all post its fantastic car you have done its really some different form all we see its perfect ..
john russakoff
Postby john russakoff » Sun Jan 05, 2014 11:55 am
JSPfab
2588 progress #3
Vista CA 92081
John@jspfab.com
trigun402
Postby trigun402 » Sun Jan 05, 2014 2:20 pm
More, I must see more. :D
john russakoff
Postby john russakoff » Thu Jan 09, 2014 3:39 pm
Fixing and changing stuff. Rearend was leaking, pulled it apart and resealed it. Doing the same for the tranny. Sold all the front suspension stuff, ordered all new custom stuff. Brake booster delete. Rerouted the line lock, waiting for the built engine still, hopefully soon. Routed the dp out the hood, the fumes inside were killing me at the track.
JSPfab
2588 progress #3
Vista CA 92081
John@jspfab.com
john russakoff
Postby john russakoff » Sat Jan 11, 2014 12:43 am
JSPfab
2588 progress #3
Vista CA 92081
John@jspfab.com
