F20/F22 AE86 Swap
Posted: Sat Sep 22, 2018 3:07 pm
Need help! F22 swap folks!!
Engine- 2005 f22 ap2
Wiring harness - done by dan from swangbiz
Immobilizer’s bypassed.
Fuel pump - walbro gca 311
Engine only cranks but does not start. Seems like
My ecu is not sending the signal to the injectors to
Activate.
I have checked the following:
1. Main harness ground behind engine block ✔️
2. Engine block to chassis ground. ✔️
3. Fuel pressure holding @ 50psi, have fuel going through
the lines and to the rail. ✔️
4. 12v on all injector connectors when ignition is on✔️
5. Checked continuity between injector connectors to
Ecu plug, got 2.0 ohms on all of them.✔️
6. Installed new injectors and checked for pulse
using noid light but failed.✖️
7. Replaced crank and cam sensors still no luck✖️
8. Swapped ecu, still no luck✖️
9. Going to pull the valve cover and check the timing.
Hope this one will fix the starting issue.
Anybody in the bay area that can help me out? I really
Need to get this thing to start!! Im getting stressed out!
Activate.
