Daihatsu Charmant
jdm86gtz
Daihatsu Charmant
Postby jdm86gtz » Tue Jan 29, 2013 6:28 am
I bought this early in 2010 with the intention of building a car to stop me doing something stupid to my '87 Trueno.
Still not quite finished but close now :roll:
Copied from http://www.ae86irl.com/ and yeah my hand usually wobbles just as i take a photo so you'll have to excuse the blurry photos
Finally picked up the Charmant yesterday and fitted my spare set of Advans to it. Good points are that there's AE86 fuel lines and hydraulic clutch fitted already and a complete late spec Levin wiring loom
She was green so gave it a good power hosing (cheers Kev:p) and then inside also as it was manky
A fine hole in the sill
I think there's a few bits missing back here
Good bits shell seam welded and painted black inside and white under the bonnet
jdm86gtz
Re: Daihatsu Charmant
Postby jdm86gtz » Tue Jan 29, 2013 6:29 am
Fitted the front end yesterday but blinked and lost the NCRAs and got RCAs in their place
If I can get the rear Cusco RCA welded to the axle that will be fitted today.
jdm86gtz
D1 spec rear pads
The mintest spot on the car
Rear axle with Cusco bushed trailing arms and pillow ball panhard rod and you can see the Cusco rear RCA below the original panhard mount on the axle
She's not mint, but she's rusty :dft003:
A previous seamless repair job
jdm86gtz
Postby jdm86gtz » Tue Jan 29, 2013 6:30 am
She got a bit of grinder and welder attention last night
And I did a bit of wire brushing this afternoon to small rusty spots
I've sort of gutted the inside now oops and the front and rear windows will be getting cut out for rust repair. 2 of the doors have been repaired with fiberglass so far also.
jdm86gtz
Postby jdm86gtz » Tue Jan 29, 2013 6:31 am
a friend was doing the metal work for me and I came out after work one day to discover all this :o
Back turned out nice :nod:
Where's my sill gone?
Ahh new steel
jdm86gtz
Postby jdm86gtz » Tue Jan 29, 2013 6:32 am
My friend Gerry that had the blue Charmant took it on himself to cut out the sill and pressed these repair sections :huh: I would have been happy with a patch up job :P I think the sill was replaced before as there is red paint under the gold (you can see some under 1 of the rear hinges) and a ball of filler.
No hammer going through this at NCT ;)
jdm86gtz
Postby jdm86gtz » Tue Jan 29, 2013 6:33 am
The poor Charmant body has lost out on the priority game, but I've collected a few engine parts:
I got a stripped small port 4A-G from Burner and got the crank polished and collected the following: TRD 0.8mm gasket, ARP head studs, ARP rod bolts, OEM rings, ACL bearings and Toda 256,264 7.9mm cams
Next have to get block skimmed and start building the bottom end and then rebuild the head.
jdm86gtz
Some pictures of the repair done around the windscreen and wiper panel, I'm surprised the windscreen didn't fall out :|
Far from it
jdm86gtz
Postby jdm86gtz » Tue Jan 29, 2013 6:34 am
What it was
How i expect the inside to look 2 seats and a steering wheel and handbrake
jdm86gtz
Postby jdm86gtz » Tue Jan 29, 2013 6:35 am
Coated the front end on both sides with 3M aerosol schutz tonight. The underneath will get something a bit thicker than this stuff though.
jdm86gtz
Painted the whole floor the other day with Hammerite smooth black
Tried on Kev's 9.5" and 8.5" Wats for the Padiflush fit, but the 8.5" on the back fit nicely
jdm86gtz
Postby jdm86gtz » Tue Jan 29, 2013 6:36 am
Fitted ACL Race main bearings and the crank tonight, I have the oil returns tidied up and ground a bit out of the bottoms of the bores as I found before that AE92 rods with ARP rod bolts touch the bores :thumpsdown:
Ran into a snag fitting the rod bolts to the rods though as there is one odd size rod nut in the pack and I have these about 3 years so I doubt I can make a claim :doh:
jdm86gtz
Postby jdm86gtz » Tue Jan 29, 2013 6:37 am
Had to mod the pistons to clear the oil squirters.
Left is OEM small port pistons and the other 2 are mine, and my template
jdm86gtz
Fitted front and rear Cusco strut braces tonight.
Nice Hammerite dribbles on the bulkhead :P
jdm86gtz
Postby jdm86gtz » Tue Jan 29, 2013 6:38 am
Rear is 15 X 8 -12 or 4" backspacing
Front is 15 X 7 -12 or 3.5" backspacing
jdm86gtz
Postby jdm86gtz » Tue Jan 29, 2013 6:39 am
They are too shiny for good pictures and they are heavy as hell
jdm86gtz
Postby jdm86gtz » Tue Jan 29, 2013 6:40 am
ot a load of parts today that I was missing
Wiper arms, bootlid seal, sill trims, door surround rubbers, LH tail light, RH front corner light, mirrors and bonnet stay. I'll have to go for another raid some other day.
jdm86gtz
Got tyres today
Gonna hide the balance weights with black paint, it was either a few grams outside or 185g stacked inside so I went this way.
jdm86gtz
Postby jdm86gtz » Tue Jan 29, 2013 6:41 am
Got my new front windscreen and the original rear screen fitted tonight :dft003: Just a good boot lid and it should be watertight and ready to get painted.
Also got the new gudgeon pin circlips I ordered so assembled the bottom end.
With my super trick ARP piston sleeve, I love how easy it makes the job :dft003:
jdm86gtz
Postby jdm86gtz » Tue Jan 29, 2013 6:42 am
Got some more parts yesterday : rusty straight bootlid, RH taillight, LH door mirror bracket:nod:, and some black dash bits
Original dented bootlid
Rusty bootlid
A bit of photoshopping and ended up with this
jdm86gtz
Postby jdm86gtz » Tue Jan 29, 2013 6:43 am
Filled the wheel well and painted it with a yard brush
and first coat of brush on stonechip crap
jdm86gtz
Moved sheds so the Trueno and Charmant are now cosy in a new unit
Built up a 4.1 with Cusco RS 2 way and solid spacer
Engine mocked with HKS copy manifold and S14 turbo
Ordered up an engine and rear axle gasket set and axle seals, had spare gearbox gasket set and 4 baulk rings so might as well refreshen the gearbox
Sitting nice on the back with a boot full of shite
jdm86gtz
Postby jdm86gtz » Tue Jan 29, 2013 6:45 am
A few pictures
Fiberglass bootlid, needs a bit of heat to get rid of the slight rise in the middle. No rust though ;)
Smoother engine bay
AE86 twin core rad, 13 row oil cooler and Evo 4 intercooler
Intercooler hardly visible from the front
Engine almost done, waiting on adjustable cam pulleys and have to get a oil return pipe tig welded into the sump
Hope the coils clear the bulkhead but will bash stuff till they do
T25G turbo now sits in a better position
Plenty of blue silicone hose
jdm86gtz
Happy with the turbo position now. Not sure if I'll keep the big awkward washer/overflow bottles or relocate the washer into the car and run an alloy coolant breather tank
Oh and the relay box is wired
Engine loom next and I/C brackets and piping
jdm86gtz
Postby jdm86gtz » Tue Jan 29, 2013 6:46 am
3 coolers are now mounted and waiting on a few reducers to complete the intercooler piping. Also got a Godspeed T25 to 3" V band turbo outlet and waiting on some 3" mandrel bends.
Toying with the idea of a brake pipe tuck as a joke. :p
jdm86gtz
Postby jdm86gtz » Tue Jan 29, 2013 6:47 am
Jackie and Dayo started at her today.
Jackie spent ages dent pulling the LH 1/4 and got it in filler and straightened out the back panel also. Started flaring the arches also.
jdm86gtz
Postby jdm86gtz » Tue Jan 29, 2013 6:48 am
Not a whole lot of news yet, but rebuilt the gearbox with new baulk rings and rebuilt the shifter with a T3 bush kit and a new Toyota boot.
jdm86gtz
Anyway collected more stuff for this, got an Odyssey dry cell battery and fake carbon box for it, a 1.2L windscreen washer bottle to fit inside the car, a nice small 0.8L alloy catch can and some gold head reflector foil to protect against the down pipe.
Also last few bits to be primed are ready to go:
Last bit of gold to be covered over
went back to the steel bootlid
engine bay ready for primer
note the flushed A/C evaporator area as the bulkhead has been shrank to be flush with the surrounding bulkhead, which is nice.
jdm86gtz
Postby jdm86gtz » Tue Jan 29, 2013 6:49 am
Only have new corner lamps the rest are old and crud.
Dayo was instructed that the only body area finish I care about is the engine bay so now it's primed he said he will leave it a while to sink.
jdm86gtz
5 base coats, 3 coats of lacquer with holographic glitter and 3 clear coats results in this:
