Page 1 of 2
2013 f20 86 build round 2
Posted: Tue Jan 22, 2013 4:06 pm
by nt66
Since i finally moved into the current century and have a phone i can post with thought I'd go ahead and share the new shell......... this car had been around for a while but just became mine officially last week going to try my hardest to have it finished for April
Re: 2013 f20 86 build round 2
Posted: Tue Jan 22, 2013 4:08 pm
by nt66
by nt66
took the car up to dallas
knocked the rest of the sound deadaning out of it
Dropped it off at Auto Comp Racecars in Ft. Worth for cage and suspension work
also got the engine for her
Posted: Tue Jan 22, 2013 4:10 pm
by nt66
finally made it up to ft worth/autocomp this past weekend (sorry dallas/ftworth bros spent the whole time working)
finished getting every last bit of sound deadaning out
chopped the front wheel wells out
along with the spare tire well
this is what she weighs in the current state should have the cage going in soon then its on to rear suspension design
also bought this thing to tow with but i'll start a new thread somewhere else
Posted: Tue Jan 22, 2013 4:11 pm
by nt66
updates!!!
marking floor for main hoop
the man marty hard at work
trying to mark out line on the floor but having trouble
switched to cardboard
bending main hoop
notching stuff up
Posted: Tue Jan 22, 2013 4:12 pm
by nt66
Posted: Tue Jan 22, 2013 4:13 pm
by nt66
rolled her out side
cut out tunnel for transmission clearance since I can no longer run subframe spacers
Honda rue made me a fancy map sensor delete and one for the brake master
motor back in
main hoop all finished
went to pull some more stuff and found a odd motor swap
Posted: Tue Jan 22, 2013 4:16 pm
by nt66
started beating inner fender for wheel clerance
motor all cleaned up
trans final cut
welding magic
halo bar fitting
more welding
tilted foward for welding the tops
bent front down bars
Posted: Tue Jan 22, 2013 4:44 pm
by Deuce Cam
I didn't notice any subframe spacers. Were you able to avoid using them by cutting the trans tunnel for clearance?
Posted: Wed Jan 23, 2013 7:43 am
by nt66
Deuce Cam wrote:I didn't notice any subframe spacers. Were you able to avoid using them by cutting the trans tunnel for clearance?
exactly... I was running the subframe spacers on the green car but can't run them on the new car because of the rules. Had to cut the trans tunnel out for clearance and I will probably have to cut a small hole in the hood to clear the end of the valve cover
Posted: Wed Jan 23, 2013 1:24 pm
by carbd7age
What was wrong with the green car? It looks so sad outside all alone.
Posted: Wed Jan 23, 2013 2:24 pm
by Zenki85
nt66 wrote:Deuce Cam wrote:I didn't notice any subframe spacers. Were you able to avoid using them by cutting the trans tunnel for clearance?
Oh yes I think I've heard of that. One of 2013's new rules. I think I read it in one of DMACs ae86 read ups on speed hunter he enforced his tunnel real well.
Great build!!!!
Posted: Tue Mar 19, 2013 6:26 pm
by nt66
Posted: Tue Mar 19, 2013 6:27 pm
by nt66
new fuel cell
got fancy with the wiring thanks to brad for the mil spec parts
new fancly quick connect fittings and lines from toxic fab for all my vaccum lines
super expensive sfi rated fire supression system
spec clutch and flywheel for the new car
new front wheels that still need to be painted white
by nt66
Posted: Tue Mar 19, 2013 6:29 pm
by nt66
by nt66
mil spec all finished up
made brackets to hold the fire bottle
painted the engine bay
sweet new dirt track steering wheel
manual rack all pretty
motor going back in
new found angle with the manual rack
never had this problem before lol
started figuring out seat brackets
new seat
turbo all shined up
fun with carbon
as she sits right now
Posted: Wed Mar 20, 2013 7:31 am
by mtmetzger
Nice progress! This thread makes me feel like I'm taking short cuts on my F22c build!
Also, Can you post some details of how you did / are going to do the drive shaft?
Posted: Thu Mar 21, 2013 11:01 am
by Warren
Top notch work, looks like you chose the right shop!
Posted: Thu Mar 21, 2013 11:35 am
by marley4us
holy crap thats bad ass
Posted: Thu Mar 21, 2013 7:32 pm
by RuizXIII
I wonder what that dude was saying in that last pic...
Pretty sweet work here, man. Engine looks fierce.
Posted: Fri Apr 26, 2013 2:48 pm
by nt66
Posted: Fri Apr 26, 2013 3:13 pm
by nt66
Posted: Fri Apr 26, 2013 3:35 pm
by nt66
Posted: Fri Apr 26, 2013 11:29 pm
by lucky13evo
No one will ever intrude your car now. lol sweet build
Posted: Fri Apr 26, 2013 11:59 pm
by yellowsnow4free
Posted: Fri May 24, 2013 5:32 pm
by nt66
by nt66
Posted: Fri May 24, 2013 5:35 pm
by nt66
going to leave this here as well
http://www.vimeo.com/66694221
Posted: Sat May 25, 2013 9:58 am
by boosted86
Top notch build! Really quality work on the whole car. Bummer about the cracked cylinder!
