ONE MILD 86
lootbag
ONE MILD 86
Postby lootbag » Sat Apr 26, 2014 6:10 am
Hey Everyone,
This is my 2nd 86, first was written off...
I have a running build log over on another local forum but thought I would share over here at Club4AG.
Just photos on this first post!
adrian.luk AT gmail DOT com
lootbag
Re: ONE MILD 86
Postby lootbag » Sat Apr 26, 2014 6:17 am
This is what has been going since late 2013 till now, the BEAMS swap.
Here is a writeup by the shop that did most of the swap for me: http://cyriousgarageworks.com/swapped-beams-3sge-ae86/
lootbag
Re: ONE MILD 86
Postby lootbag » Sat Apr 26, 2014 6:18 am
Installed the CUSCO front radius bar... loks nice
Swapped out the 195/50 in front for a 225/50 to match the rear and installed the Zenki front lip
Sapporokid
Re: ONE MILD 86
Postby Sapporokid » Sat Apr 26, 2014 1:06 pm
Is that a rx7/ae86 rear diffuser?
looks very nice! love that beams haha
YOTAHOLIC808
Re: ONE MILD 86
Postby YOTAHOLIC808 » Sun Apr 27, 2014 10:14 am
Any vids of it running? ~ Looks amazing! good work!
@_yotaholic
Oni-Roku
Re: ONE MILD 86
Postby Oni-Roku » Sun Apr 27, 2014 1:44 pm
Oh man.....makes me want to build my ae86 so bad :( but I have to wait till oct
R-Rydes
lootbag
Re: ONE MILD 86
Postby lootbag » Sun Apr 27, 2014 2:51 pm
Sapporokid wrote:Is that a rx7/ae86 rear diffuser?
Yeah it is a Shine Auto RE-Amemiya Replica for FC
YOTAHOLIC808 wrote:Any vids of it running? ~ Looks amazing! good work!
No vids yet... maybe soon?
Oni-Roku wrote:Oh man.....makes me want to build my ae86 so bad :( but I have to wait till oct
Why the long wait?
lootbag
Re: ONE MILD 86
Postby lootbag » Tue Jul 29, 2014 7:37 am
Some updates from May.
Since then, I have just been driving the car as much as I can and been to a few track days.
Replaced the HAWK HP+ with WINMAX W4 pads and went with Rota Grid Classic 9J -15 & Hankook R-S3s in 225/45-15 for the track setup.
Really need to get an oil cooler setup going because temperatures were hitting 135 degrees after 5 hot laps.
The o-ring for the dipstick tube has a slight leak which only occurs on the track under constant high pressure.
That's about it for the problems so I am really satisfied, more lapping days to come.
jeepy
Re: ONE MILD 86
Postby jeepy » Tue Jul 29, 2014 8:25 am
are you gonna be there at the cyrious garage 86 meet next week?
saiGone
Re: ONE MILD 86
Postby saiGone » Tue Jul 29, 2014 12:44 pm
Dope zenki! Flares and diffuser make it look raw
grappletech
Re: ONE MILD 86
Postby grappletech » Tue Jul 29, 2014 7:55 pm
Nice beams swap
87 SR5 Coupe Shell. (Sold)
86 SR5 Hatch Shell
86 GT-SR5 Coupe 20v Swap
lootbag
Re: ONE MILD 86
Postby lootbag » Sun Dec 14, 2014 8:09 am
86 as it sits today,
it will never be done.
LongGrain
Re: ONE MILD 86
Postby LongGrain » Sun Dec 14, 2014 2:45 pm
What adapter did you use for your quads? Xcessive? If so did the itg plate bolt right on?
Clouds
Re: ONE MILD 86
Postby Clouds » Sun Dec 14, 2014 3:41 pm
It's sooooooo nice! :) Where is a drooling emoticon when I need it?
lootbag
Re: ONE MILD 86
Postby lootbag » Sun Dec 14, 2014 5:37 pm
LongGrain wrote:What adapter did you use for your quads? Xcessive? If so did the itg plate bolt right on?
Xcessive yes, and the ITG plate from SQ did work but I ended up taking off those quick release fasteners and using bolts and nuts to secure the two together.
Slightly sanded down edges to make the fit tighter as well.
Your BEAMS86 is pretty rad by the way!
Clouds wrote:It's sooooooo nice! :) Where is a drooling emoticon when I need it?
Thanks!
LongGrain
Re: ONE MILD 86
Postby LongGrain » Sun Dec 14, 2014 5:45 pm
Cool, thanks. I was curious because the ITB spacing with the xcessive adapater is a little different than it is on the 20v, so I wasnt sure if the bolt holes would all line up perfect.
lootbag
Re: ONE MILD 86
Postby lootbag » Sun Dec 14, 2014 6:10 pm
LongGrain wrote:Cool, thanks. I was curious because the ITB spacing with the xcessive adapater is a little different than it is on the 20v, so I wasnt sure if the bolt holes would all line up perfect.
I believe the bolt and ITB holes lined up decently but need a tiny trim here and there.
Its been about a year since the swap, so the memory is a bit rusty.
lootbag
Re: ONE MILD 86
Postby lootbag » Thu Jun 25, 2015 3:53 pm
Back in town and starting to spend some quality time with the car.
bumper cut and wanggg for now
working on some other things
Demented86
Re: ONE MILD 86
Postby Demented86 » Thu Jun 25, 2015 6:54 pm
That is one sexy corolla man!
"Life's simple. You make choices, and you don't look back."
Toy86
Re: ONE MILD 86
Postby Toy86 » Fri Jun 26, 2015 1:30 pm
Great Beams swap, and great looking 86! One question, how wide are the rims you running? Also, why did you chop up ur rear bumper for? Thanks and good luck on ur following track days!
lootbag
Re: ONE MILD 86
Postby lootbag » Mon Jun 29, 2015 7:35 am
Toy86 wrote:Great Beams swap, and great looking 86! One question, how wide are the rims you running? Also, why did you chop up ur rear bumper for? Thanks and good luck on ur following track days!
15x9 -15 square setup with 225/45-15 tires
Chop the bumper for "less drag", not really, its just for the look I like.
ae86714
Re: ONE MILD 86
Postby ae86714 » Mon Jul 06, 2015 11:40 am
lootbag wrote:Installed the CUSCO front radius bar... loks nice
Pretty sure this is incorrectly installed...
lootbag
Re: ONE MILD 86
Postby lootbag » Tue Jul 07, 2015 3:17 pm
ae86714 wrote:Pretty sure this is incorrectly installed...
Did I? I just followed what I saw on the web.
Deuce Cam
Re: ONE MILD 86
Postby Deuce Cam » Wed Jul 08, 2015 10:55 am
^That's right. I also have one.
ae86714
Re: ONE MILD 86
Postby ae86714 » Fri Jul 10, 2015 9:28 am
:oops: My mistake, I was thinking it was supposed to attach to the ends of the tension rods like some other styles I've seen. And now looking at the bends in the cusco bar, it doesn't even look possible to attach the way i was thinking.
lootbag
Re: ONE MILD 86
Postby lootbag » Wed Jul 22, 2015 6:14 am
ae86714 wrote::oops: My mistake, I was thinking it was supposed to attach to the ends of the tension rods like some other styles I've seen. And now looking at the bends in the cusco bar, it doesn't even look possible to attach the way i was thinking.
Haha it's alright, I could see how that gets confusing.
CAD some new wingstands
Now the wing is roof height :mrgreen:
Installed a fuel surge tank setup to deal with the pesky fuel cut in hard cornering
Free time attack session, so I joined.
Got bored and attempted to make a front splitter.
It is still a work in progress, need to make canards and endplates to finish the front aero.
This is the front end aero setup I am aiming for.
http://i.imgur.com/FSUxvsp.jpg
Sctjaramillo
Re: ONE MILD 86
Postby Sctjaramillo » Fri Jul 24, 2015 1:18 pm
Nice build
GTS_007
Re: ONE MILD 86
Postby GTS_007 » Sat Jul 25, 2015 2:45 pm
what kind of wing is that ?
lootbag
Re: ONE MILD 86
Postby lootbag » Mon Jul 27, 2015 8:54 am
GTS_007 wrote:what kind of wing is that ?
Should be a Voltex Type 2 1600mm.
Users browsing this forum: No registered users and 18 guests
