shagymc wrote:The mirrors do just pop out however they are pretty fragile. I suggest kind of bending a corner and just slowly working the plastic off of it around the mirror.
This is the best video I've seen of how to twist the wires:
https://www.youtube.com/watch?v=uTJhrTTl-EE
You are going to want to tie off one end of the wires to something. I usually screw a screw in a little bit on the bench and then tie the strands to it. Just like the video shows, you'll then put the other two ends into the drill and tighten down. As you tighten, you'll have to move forward as the wire length shrinks. You'll also want to keep the wires taught as you do this to keep the twist even throughout.
Try it out with some scrap wire first! Hope this helps and thanks for the feedback. Hopefully I'll have them figured out by this weekend.
Awesome video, and thanks for the info!
