Page 3 of 8
Re: 5.5ag 20v Coupe
Posted: Wed Mar 13, 2013 8:08 am
by oldeskewltoy
gaijin_rokurunner wrote:Bad news unfortunetly the engine blew on the dyno today but made 252hp and 164 ftlbs torque at 9000 before it went boom...Sandy at the shop said the lowest torque figure was 140 ftlb which is outstanding...he also said with a dry sump, longer runner intake and a little more c/r this thing would of made 280hp range bo problem he was very impressed...anyhow we suspect incorrect valve to piston clearence in the number 2 cylinder as one of the valve hit a piston over and over till it snapped which in turn tore up the piston and other valves...heading to the shop tomorrow to see the damage...they are investigating if its a part problem which would mean coat to rebuild is out of my pocket or builder error which they would cover everything free of charge...called Zeke down at Ferrea and he told me the valves i have are top of the line before titanium and are not made to break but bend and that fact that one broke means it hit the piston continuously till it snapped again meaning inproper valve clearence...anyhow keep u posted will probably take a while to rebuild since everything is custom more then likely need a new head which will require a whole new port and valve job as well as flow benching then if the cylinder wall is trashed a whole new block...no fixing 83mm bores... On a good note made more hp then the f20 and f22 as well as a FA so my money is well spent in my book....pictures to come
Good luck on the future.... 164#/ft is pretty good.
Besides the piston to valve clearance, I'd also check the valve springs... one reason the Atlantics go over 10,000 is because the valve springs are more than capable (dual), and it seems odd that one piston was machined incorrectly... or one valve was mis-seated. It seems more likely that a spring was not up to the task... floated... and BOOM.....
Re: 5.5ag 20v Coupe
Posted: Wed Mar 13, 2013 6:43 pm
by gaijin_rokurunner
Re: 5.5ag 20v Coupe
Posted: Wed Mar 13, 2013 8:57 pm
by oldeskewltoy
Can see that the valves were hitting all the pistons... impressed with how long they held up in that environment. Good luck, and it seems like you/they found the cause.
Re: 5.5ag 20v Coupe
Posted: Thu Mar 14, 2013 3:52 pm
decided to bump c/r up to 14.1 since the engine is apart and invested in a Hy-tech header....the bill keeps getting bigger is there no end to spending money on these damn cars and engines !....
Re: 5.5ag 20v Coupe
Posted: Fri Mar 15, 2013 2:52 pm
by RuizXIII
You are the only guy who is optimistic about his engine blowing up! Haha
It sucks that it blew up but seems like you are going to make it even cooler next go 'round!
I can only imagine...
Re: 5.5ag 20v Coupe
Posted: Fri Mar 15, 2013 5:46 pm
by eightsixgts
RuizXIII wrote:You are the only guy who is optimistic about his engine blowing up! Haha
I would be if I didn't have to pay for the repairs, too.
Re: 5.5ag 20v Coupe
Posted: Fri Mar 15, 2013 5:52 pm
Yeah dont have to pay for anything since it was their error ...i did buy a hytech header so i ended up spending money anyways lol
Re: 5.5ag 20v Coupe
Posted: Fri Mar 15, 2013 10:18 pm
by Orange Rocket
Good Luck!
Re: 5.5ag 20v Coupe
Posted: Sat Mar 16, 2013 7:46 pm
Thanks Orange Rocket...what are u building now i see u sell alot of parts but also buy alot?
Re: 5.5ag 20v Coupe
Posted: Sat Mar 16, 2013 8:55 pm
by 8-Eight_Six-6
Maaaan that's such a bummer dude. Good luck with the rebuild.
Re: 5.5ag 20v Coupe
Posted: Sun Mar 17, 2013 12:58 am
by Orange Rocket
gaijin_rokurunner wrote:Thanks Orange Rocket...what are u building now i see u sell alot of parts but also buy alot?
I need to sell my extra parts to go next project. haha
It's seems like your piston tops are 0.3mm to 0.5mm higher than the deck.
1)Quicksilver decked too much for the piston you made?
2) CP mis design the piston pin height?
3) piston dome wasn't hi enough so, used thin gasket to increase compression ratio.
many reasons I can think of
Anyway, if you ever going to re-make whole set of pistons, I would suggest you to make longer rod as well.
CP can make shortest piston pin height for 22.5mm with 3 rings.
5.5 AG has too much pressure to the side wall.
Oh, One more, You might want to use Longer Valve guides.
I can't wait to see next post!
Re: 5.5ag 20v Coupe
Posted: Sun Mar 17, 2013 5:38 am
No the block has 0 deck height i just think its the angle of the picture that looks like that...I sent cp an original HKS piston from the 5ag kit as well as the stock 20v piston which at 83mm and 1mm head gasket made it 12.2:1 c/r then the did a thin head shave to get 12.6:1. There is nothing wrong with the short block everything was done properly. Quick silver has been building 4ages before hasselgren, Elite and just about as long as Loyning so they know what they are doing. As far as the side walls the block has been cemented half way up the waterjackets so there is no worry about pressure on the side walls...the whole incident was a simple mis calculation of the valve pocket angle on the deep side thus the edge of the valves hit mid way down...which is why they are covering the cost to fix it. I dont think longer rods are a good idea for the 5ag due to the already longer stroke...the pin has already been moved up far where the pistons already use three rings...also i chose to use the same dome height as the stock piston because of the shape of the combustion area which is very flat compared to the 16v...i think the setup will be fine once the rebuild is done and the reliefs are corrected...the hp made already suggests a good build since nobody has made that much on a 20v to date and it wasnt even tuned 100% when it blew. Once its all done with the changes made and the new header i pedict the mid to high 260s at 9500...anything over 250 is satisfactory to me ...tecarts 7ag 20v only makes 200hp and thier 5ag 20v in Toshiki Yoshioka Team Droo-p AE86 only made 230hp...
Re: 5.5ag 20v Coupe
Posted: Tue Mar 19, 2013 3:59 am
by Davegt27
Wow I have to come over to Club4ag more often this is way cool, thanks for the build thread
I have a 5AGZE so what makes a 5.5AG?
The term is piston side loading and that’s what orange rocket is referring to it has to do with bore to stroke ratio
My HKS crank was 3.265 stroke instead of 3.267(83mm) so it was a little short of 83MM
My pistons came from Wiseco and the ring package gets pretty tight (I use 18mm pin Carrillo rods)
Looking forward to the next dyno results
Re: 5.5ag 20v Coupe
Posted: Wed Mar 20, 2013 7:47 am
5.5ag is 83mm bore 83mm stroke..i dont think when u get into the .000 area it technically matters or makes a difference as its so minuet its mathematically the same. As far as side loading...my skirts are a lot shorter then stock and have also been coated to reduce that friction plus as i show in my thread my block has been cemented which strengthens all 4 cylinders tremendously. A lot of people dont do that when they bore to 83mm which puts them at risk especially if their block is not bored or honed properly....mines was all done at operating temp which reduces wear on the cylinder walls where as people who bore and hone their engines at room temp see extensive wear on the cylinder walls and rings at operating temps and the cylinders change in shape due to heat. My pistons are CP and incorporate a different design then Wiseco...should be a couple weeks before we are up and running again...CP is slow making pistons 3-4 weeks for one...and have to get a few valves made also...
Re: 5.5ag 20v Coupe
Posted: Wed Mar 20, 2013 8:49 am
by oldeskewltoy
gaijin_rokurunner wrote:5.5ag is 83mm bore 83mm stroke..i dont think when u get into the .000 area it technically matters or makes a difference as its so minuet its mathematically the same. As far as side loading...my skirts are a lot shorter then stock and have also been coated to reduce that friction plus as i show in my thread my block has been cemented which strengthens all 4 cylinders tremendously. A lot of people dont do that when they bore to 83mm which puts them at risk especially if their block is not bored or honed properly....mines was all done at operating temp which reduces wear on the cylinder walls where as people who bore and hone their engines at room temp see extensive wear on the cylinder walls and rings at operating temps and the cylinders change in shape due to heat. My pistons are CP and incorporate a different design then Wiseco...should be a couple weeks before we are up and running again...CP is slow making pistons 3-4 weeks for one...and have to get a few valves made also...
same here....
just as an inquiry... are the suzuki valves similar mass to yours? I'm sure Quicksilver, and Ferrea know what they are doing, I was just wondering outloud.
Re: 5.5ag 20v Coupe
Posted: Wed Mar 20, 2013 8:56 am
Not sure about suzuki but Zeke at Ferrea said they are simular to the yamaha motorcycle 5 valves in size..which makes sense since the head is yamaha made...my valve springs are a variation of moto gp suzuki springs with a bew retainer and seat to fit the 20v head
Re: 5.5ag 20v Coupe
Posted: Fri Mar 22, 2013 10:44 am
by burdickjp
gaijin_rokurunner wrote:There is nothing wrong with the short block everything was done properly.
Except, apparently, piston to valve clearance.
gaijin_rokurunner wrote:the whole incident was a simple mis calculation of the valve pocket angle on the deep side thus the edge of the valves hit mid way down
This is easy to check with plasticine. I'm rather surprised a shop you tout as being as good as they are made such an amateur mistake.
Better luck next time.
Re: 5.5ag 20v Coupe
Posted: Fri Mar 22, 2013 11:01 am
Re: 5.5ag 20v Coupe
Posted: Sat Mar 23, 2013 12:53 pm
by burdickjp
Re: 5.5ag 20v Coupe
Posted: Sat Mar 23, 2013 2:29 pm
Sold my Header and bit the bullet for one of the very expensive but top notch Tri-Y Hytech headers from John at Hytech......never knew this but John worked for Quick Silver Race engines long time ago....he and Sandy are actually really close!!! Still had to pay full price haha but this design is based off the Formula Atlantic design just re-bent to fit the AE86 platform...Thanks to Billy Andrea for being the first person to get one made opening the door for others....John has a Jig setup so you dont have to take your car there for a custom build
Re: 5.5ag 20v Coupe
Posted: Sat Mar 23, 2013 3:29 pm
by burdickjp
Re: 5.5ag 20v Coupe
Posted: Sat Mar 23, 2013 3:51 pm
Re: 5.5ag 20v Coupe aka Orions Demise!
Posted: Sat Mar 23, 2013 4:25 pm
Setting up the s2000 gauge cluster.....what a pain in the ASS! all the wiring is done...I think well at least what features apply to the AE86....took the JSP panel and put some 3m textured carbon fiber vinyl on it...cut out 2 holes for my EGT gauge and my Oil Pressure...should look good when im done. Bought a custom carbon fiber HVAC delete from Carbon Fiber Collections in Hawaii to fit all my Omori gauges...looked good but fitment kind of sucks so Im debating if im going to use it now....cant fit the stereo surround under it in properly...so might ditch it if i can trim it properly!
Re: 5.5ag 20v Coupe
Posted: Sat Mar 23, 2013 5:13 pm
by burdickjp
Re: CONSUMER 5.5ag 20v Coupe...dedicated to Orions Demise!
Posted: Sat Mar 23, 2013 5:55 pm
blast for the past
Posted: Sat Mar 23, 2013 6:20 pm
by burdickjp
Posted: Sat Mar 23, 2013 7:07 pm
by Zenki85
I think you two are both doing great work!
Thanks Zenki....its hard being a Consumer!!!
Posted: Sat Mar 23, 2013 7:10 pm
Finished my rear end up....added my revolver traction brackets, and installed the N2 panhard support bracket which bolts to the frame and supports the side to side pressure put on the factory panhard mount....these things can crack and are a pain to reweld...In the future I will install a Watts link setup similar to the one pictured but SS Works makes one that actually bolts on instead of welding the mount to the center of the diff housing.
Posted: Sat Mar 23, 2013 7:27 pm
after 10 years of storage....original OEM stickers have a home
