Ok so a while back i seen all the diy led upgrades that were going around on the net. so, i decided to try it on my own car. quite an experience, there is a lot of work that goes into these, so i cant disagree with someone charging $500+ to make a set (i would probably charge the same). so by checking out the newer cars equipped with led tail lights, i figured out how i wanted to design mine. i believe it was an Audi that inspired my led design. if you plan on attempting something like this, do your homework, learn the led and resistor values, search, search, search... is the best advice i can give you. so on to the pictures..
here is my led boards all put together and installed. each large board holds 99 leds
 running light, reverse light and signal on
brake light, reverse, and signal on
now installed on the car
running lights
brake lights
signals lights
reverse lights
later in the day shots
