4age ITB smog
Be nice to others.
rollaboy831
4age ITB smog
Postby rollaboy831 » Sun Apr 28, 2013 8:47 pm
hey fellow rolla owners im swapping a 4age in to my sr5 and i was thinking of goin big and don the ITBs but i dont know it can pass smog like that. any info will help thanks!!!!!!!!1
mikeyee
Re: 4age ITB smog
Postby mikeyee » Sun Apr 28, 2013 10:03 pm
cali smog? not gonna pass legitimately mayne.
ga_goosh
Re: 4age ITB smog
Postby ga_goosh » Mon Apr 29, 2013 7:59 am
+1 there is no egr valve so the only state you will be able to pass in would be the states that do 25 year exemtions
I <3 my AE86
4AG Manual
AE86 FSM
ronny
Re: 4age ITB smog
Postby ronny » Mon Apr 29, 2013 11:10 am
Rays - Project Mu - TE37 club
BLUE MOON / CUSCO
AE86fightclub.com
PM me for Contact
carbd7age
Re: 4age ITB smog
Postby carbd7age » Mon Apr 29, 2013 11:37 am
You gotta move mangh. We have testing in our county here in Tennessee, they pressure check the gas cap, look under the car for a cat, and scan for OBD2 codes or sniff old cars. Takes 10 bucks and 10 minutes. Cali blows donkeys.
Knockoff Crew member #0001
SidekickChuck
Re: 4age ITB smog
Postby SidekickChuck » Mon Apr 29, 2013 1:11 pm
You gotta know a guy who knows a guy
2001 Carbon Black e39 M5
Zenki85
Re: 4age ITB smog
Postby Zenki85 » Tue Apr 30, 2013 7:59 am
SidekickChuck wrote:You gotta know a guy who knows a guy
+1
Or have that mula, it ain't ever gonna be cheap
Unless you know the "guy" not know a guy who knows a guy
TEAM 'CLASSIC
A 'CLASSICALIFORNIACAR
Re: 4age ITB smog
Postby Deuce Cam » Tue Apr 30, 2013 8:46 am
carbd7age wrote:You gotta move mangh. We have testing in our county here in Tennessee, they pressure check the gas cap, look under the car for a cat, and scan for OBD2 codes or sniff old cars. Takes 10 bucks and 10 minutes. Cali blows donkeys.
Whaaa.........only $10!? The crooks in AZ charge $28!
Turtle
Re: 4age ITB smog
Postby Turtle » Tue Apr 30, 2013 10:18 am
Do your swap CA compliant, get it working properly, pass smog. Then do the ITB conversion and keep the CA compliant stuff in a box in your garage. When it's time to get smog, swap the CA compliant stuff back. when you're done passing smog, put your ITBs back on for 2 years. it's that simple.
R
carbd7age
Re: 4age ITB smog
Postby carbd7age » Wed May 01, 2013 4:19 am
ga_goosh
Re: 4age ITB smog
Postby ga_goosh » Wed May 01, 2013 4:26 am
lol here in Texas it is 14.50 no cat check and no smog sniffer or cap testing for cars that are 25 years and older. only thing that is checked is horn lug nuts tires tint and lights....basically just a safety check
I <3 my AE86
4AG Manual
AE86 FSM
Re: 4age ITB smog
Postby MisterJerk » Wed May 01, 2013 5:25 am
$13 in VA. 25 year no emissions, just safety inspection.
ae86xy
Re: 4age ITB smog
Postby ae86xy » Tue May 07, 2013 10:12 am
Here in WA. They check gas cap charge you 15.00 your done
85z3nki
Re: 4age ITB smog
Postby 85z3nki » Wed May 08, 2013 8:53 am
In IL they do nothing for cars that arent OBDII and up. Just give them 98 dollars every year for a new sticker for your plate.
Esenpai
Re: 4age ITB smog
Postby Esenpai » Thu May 16, 2013 4:23 pm
it probably is possible. though you'll need a snap on plenum to go over the itbs of some sort and will need to mock up vacuum lines and route the erg piping to the plenum. it would be quite involved to make the whole set up but once you have it you can just take it on and off as you need.
as long as it has he vacuum lines going to a vacuum and the egr piping goes to the plenum you could probably get away with it. since they can't check for egr function or anything like that. you'd also need a afm. but you could hollow one out I suppose. just go to a guy who's never seen a 4ag before lol.
or you could just do what turtle said.
sounds crazy but it might work.
SidewaysGts
Re: 4age ITB smog
Postby SidewaysGts » Wed Aug 07, 2013 5:02 am
110% indeed possible if you use all the required emissions equipment. But in all honesty, such a set up would be less than fun to set up properly for an ITB setup, and would dampen many of the relatively few benefits of running ITBs in the first place.
The BEST bet if you want a "smog legal" ITB car where you dont have to know a guy who knows a guy and fork out some extra cash? Keep a factory set up for swapping in to smog the car once a year. If youre "smart" with your swap, and handy with a wrench, its actually not as much of a pita as you might expect- And once youve done it, well, once- Its a cake walk every time after that. Ive pulled my car into the garage in the morning and driven out with a new engine by lunch time.
No need to worry about knowing shadey individuals, no need to grease palms- Just suck it up once a year and set aside the weekend it takes to do it, and bobs your fathers brother.
NateTheRipper
Re: 4age ITB smog
Postby NateTheRipper » Sat Aug 09, 2014 6:16 am
Tucson it's 12.50 to smog $28 might be in phx
05 WRB STI (prostitution whore)
04 Forester XT (sleeper)
97 Blazer (mule)
85 GTS Coupe (Old Lady)
07 TC (sold)
04 Corolla (sold)
89 Supra Turbo (RIP)
85 Supra P-type (RIP)
89 Supra Turbo (sold)
Re: 4age ITB smog
Postby yoshimitsuspeed » Sat Aug 09, 2014 5:01 pm
rollaboy831 wrote:hey fellow rolla owners im swapping a 4age in to my sr5 and i was thinking of goin big and don the ITBs but i dont know it can pass smog like that. any info will help thanks!!!!!!!!1
You say going big and I don't know if big for you is looks or performance but you might consider this.
ITBs will not be a performance upgrade with internals that will allow you to pass emissions. Is it really worth it to take the risk for a glam mod that is really just about looks and sound?
Turtle wrote:Do your swap CA compliant, get it working properly, pass smog. Then do the ITB conversion and keep the CA compliant stuff in a box in your garage. When it's time to get smog, swap the CA compliant stuff back. when you're done passing smog, put your ITBs back on for 2 years. it's that simple.
R
And then be one of those guys who comes back on the forums complaining about how they got caught by the cops and have a court date and expensive fines and don't understand why they got in so much trouble for something even though they knew they were breaking the law.
