Camshafts... What is your desire??
Be nice to others.
Postby oldeskewltoy » Thu Mar 21, 2013 12:13 pm
As many of you know I've been working on clearing space @ a local race shop.
Well, they have BOXES of old camshafts... there are picking through the lot to see which ones are either repairable, OR grind-able to new dimensions......
And here is where you come in... What is wanted?
Would you prefer repaired 288+ duration 9.5+mm lift cams??
OR...
Would you prefer these cams be ground to 272 or less durations, with lifts under 9mm???
expected price on these should be under $500 for a pair
So what say you?????
carbd7age
Re: Camshafts... What is your desire??
Postby carbd7age » Thu Mar 21, 2013 8:11 pm
272/9.0mm sounds good to me, 288's are a little too spicy. I need something to wake up my motor, I have Comp valve springs with a really high lift capacity.
Knockoff Crew member #0001
Postby MisterJerk » Fri Mar 22, 2013 4:41 pm
264's 8.5mm lift or w/e you can run with stock buckets would probably be a better seller. especially in the low $400s. kinda like a discount poncam. I would be up for a set in that price range.
BlueDeathTrap
Postby BlueDeathTrap » Fri Apr 12, 2013 12:51 am
Regrettably these cams are for the wrong motor, otherwise I'd say gimme some 288s with 10mm lift! :mrgreen:
Postby oldeskewltoy » Fri Apr 12, 2013 8:25 am
BlueDeathTrap wrote:Regrettably these cams are for the wrong motor, otherwise I'd say gimme some 288s with 10mm lift! :mrgreen:
What engine would you like 288/10mm cams for???
Pogipoints619
Postby Pogipoints619 » Fri Apr 12, 2013 9:04 am
+1 For the 256/264, mild street able.
Free Wing Chun/kickboxing training sessions in the SoCal Murrieta/San Diego
Saturdays
BlueDeathTrap
Postby BlueDeathTrap » Fri Apr 12, 2013 12:31 pm
1UZ-FE. I haven't even gotten the base engine running yet (lack of funds), so I'm sure 288s or the like would be a bit much for just getting to know my new setup :lol:
Plus going SUB on the 1UZ is not a cheap option like it is for the 4AGE. Lots of parts cross referencing and mixing and matching to make it all work.
