Noob question hour! AE86 brakes?
Be nice to others.
IndiaDorifto7
Postby IndiaDorifto7 » Sun Oct 19, 2014 5:38 pm
So I just got my ae86 and the brakes feel soft, a bit too soft. :? To remedy this, do I just need to bleed the brakes or is it something more than that?
Clouds
Re: Noob question hour! AE86 brakes?
Postby Clouds » Mon Oct 20, 2014 5:12 am
IndiaDorifto7 wrote:So I just got my ae86 and the brakes feel soft, a bit too soft. :? To remedy this, do I just need to bleed the brakes or is it something more than that?
I think that means that you need to bleed the brakes really well, so that no air is in the system. I'm sure that someone else here will be able to help you a bit better, though.
davew7
Postby davew7 » Mon Oct 20, 2014 5:15 am
The real issue is how did the air get into the system. Check all the calipers and the master cylinder for any signs of brake fluid leaking around the pistons or M/C push rod. There could also be the possiblity that the hoses are so old that they are expanding under pressure, so check there condition as well. Dave W
Clouds
Postby Clouds » Mon Oct 20, 2014 5:17 am
See? Look at that! Already, another reply. ^^
saiGone
Postby saiGone » Mon Oct 20, 2014 8:09 am
Yup bleed brakes. Did you get a Haynes manual/ dl the FSM?
Could be master cylinder.
Could be your rubber break lines at the calipers. These get old with time and become some-what spongy. People like to replace them with stainless braided lines.
SidekickChuck
Postby SidekickChuck » Mon Oct 20, 2014 8:16 am
How long has it been since the brake fluid was changed completely? Brake fluid is hygroscopic, so it naturally absorbs moisture. Might be a good idea to flush all the old fluid out with new after replacing the old rubber lines. Might as well get a good set of pads in there while doing this work also, unless you already have a good set.
2001 Carbon Black e39 M5
Postby oldeskewltoy » Mon Oct 20, 2014 9:47 am
When bleeding AE86 brakes.... its best to have a block, or other limiting device, because the problem you are having may have been caused by brake bleeding!!!
I'm not sure of the reason... but if the AE86 master cylinder gets "bottomed out" it can cause tiny leaks to enter the master cylinder.
The only way to know this is to bleed the brakes(done when the car is not running), start the car, and CLOSELY watch the master cylinder reservoir as a friend presses down on the brakes (with the car running). IF tiny bubbles, bubble up and the pedal goes soft again, you need to replace the master cylinder.
When ever I bleed AE86 brakes by pumping the pedal... I tape a 4x4 block under the pedal so it can't bottom out
Glock30
Postby Glock30 » Mon Oct 20, 2014 10:14 am
Not sure if it's a GTS or SR5, but if it's an SR5 check the wheel cylinders...
1984 Toyota Corolla Sport SR5
1989 Ford Bronco Eddie Bauer
1968 Ford F250
Lots of 4AC info here: http://4ac-powered.forumotion.com/
IndiaDorifto7
Postby IndiaDorifto7 » Mon Oct 20, 2014 8:54 pm
It' a GTS, Thanks for the advice guys! Bleeding the brakes is definitely on my to do list now, And also, are there any other brake problems I should look out for?
.TRD.TRUENO.
Postby .TRD.TRUENO. » Tue Oct 21, 2014 9:51 pm
One of the first things I did when I got mine was indeed to bleed the brakes and throw in some Hawk pads... Nothing beats the fresh pedal feel with new pads.
branden
Postby branden » Mon Nov 10, 2014 10:07 am
^ hawk pads with stainless braided lines. feels awesome
InitialB
Postby InitialB » Mon Nov 24, 2014 5:25 pm
^Winmax pads with stainless braided lines. Feels fantastic
