WATER in my engine
Be nice to others.
vangman209
WATER in my engine
Postby vangman209 » Tue Sep 09, 2014 1:40 am
well my engine locked and we cranked the bottom nut and water shot out of my 2 right cylinders what can i do to fix it? i drive and ae92 the motor is a red top. any suggestions help no bs plz
Jimmee1990
Re: WATER in my engine
Postby Jimmee1990 » Tue Sep 09, 2014 3:29 am
If there's water inside the cylinders there's not a lot of point in trying to save it with dodgy fixes, just pull the engine out and tear it down and replace what needs to be replaced.
Postby jondee86 » Tue Sep 09, 2014 3:58 am
Head gasket is blown... pull the head and see if there is any
other damage. If you get lucky a good clean and a fresh factory
head gasket could have you up and running. Just make sure you
change the oil and filter to get as much of the water out as you
can before firing it up.
vangman209
Postby vangman209 » Tue Sep 09, 2014 8:19 pm
thanks guys
