Page 13 of 14
Re: What did you do to your car today?
Posted: Wed Apr 01, 2015 8:11 pm
by ritz
Slap different wheels on last week
Posted: Sun Apr 12, 2015 5:46 am
by Jimmee1990
Drove it for the first time in nearly a year. Loving having a lot more power now too, 282 cams running perfectly on the standard MAP ECU.
Posted: Wed Apr 15, 2015 1:11 pm
by norbertopy
i buy hin a TRD shift knob
Posted: Sat Apr 18, 2015 11:34 pm
by ejmr20
Posted: Sat May 02, 2015 6:18 am
by HingaSPL
Woke my baby from her long slumber, My buddy figured out my wiring problem, I changed her worn alternator belt n washed her. Charge light came on, on the way home. Will figure it out Monday when I'm off
Posted: Sat May 02, 2015 11:23 pm
by lonelywanderer
Got my a/c working in time for summer and fixed my cel problem
Posted: Sun May 03, 2015 8:17 am
by Grant
lonelywanderer wrote:Got my a/c working in time for summer and fixed my cel problem
What was wrong with your A/C? Need to get mine tested/charged too...
Posted: Mon May 04, 2015 8:16 pm
by lonelywanderer
Grant wrote:What was wrong with your A/C? Need to get mine tested/charged too...
Car just sat for 10 or so years and the r12 was really low so converted it over to r134a.
Posted: Tue May 05, 2015 6:03 pm
by Grant
Nice! Did you replace all the o-rings, or just evac and recharge?
I'm thinking of charging with R12A (very different from R12) since it's supposed to be better for original R12 systems.
Posted: Wed May 06, 2015 12:02 am
by lonelywanderer
changed the o rings in the engine bay along with the reciever drier. then evac and charged
Posted: Mon May 25, 2015 11:03 am
by -zenki-
Soldered a new h4 plug on for the left headlight and fixed some crappy wiring.
Posted: Tue May 26, 2015 9:41 am
by s3cf
changed the shifter bushing
Posted: Wed May 27, 2015 1:43 am
by ejmr20
Finally got my intake installed
Posted: Wed May 27, 2015 3:24 am
by Jimmee1990
Swapped my RunFree front bumper over to Zenki Levin to make it a little more street friendly, and cleaned up the new 14x7's and bolted them on.
Posted: Sun May 31, 2015 2:30 pm
by -zenki-
Spend the weekend cleaning the enginebay. What did i get myself into... Probably hasn't been cleaned in 20+ years. Dodgy repairs and grime everywhere. Also my distribitor o-ring is leaking so there's oilspray on everything.
Posted: Sat Jun 13, 2015 11:29 am
by -zenki-
About halfway through my distributor rebuilt. Got 2 new seals on, drilled out the little pin in the shaft/gear. Still have to get a bearingpuller to get the bearing out and replace the inner seal.
Finished most of the enginebay cleanup and retaped alot of the wiring in wiring loom cloth tape.
Posted: Mon Jun 15, 2015 8:17 am
by saiGone
Fixed the timing with a cheapo Harbor Freight timing light.
Finally pulls strong!
Posted: Tue Jun 16, 2015 8:43 pm
by dellaVeritas
Started working on my bent strut casing
Posted: Wed Jun 24, 2015 7:19 pm
by shadowwolf151
Didn't do it today, It was a few weeks ago while I was back home on leave. Replaced the busted P/S rack with a re-manufactured one, inner and outer tie rods, tape measure front alignment (totally nailed it, drives perfectly straight), finally fixed the shotty wiring job the previous owner did for the amps and speakers he put it, (BTW there is no reason to have 4 6x9 in the back window, and 2 6" speakers in the back seat side panels), replaced driver and passenger door panels with some clean ones I bought on FB, (again, previous owner decided to paint the old one black with oil based paint, so it ran, dripped, and melted in the heat), and replaced both front seat-belts with universal 3-point replacements, all in one day. This car need a lot of TLC, and I still have a ways to go, but it will be worth it in the end
Posted: Sat Jun 27, 2015 1:31 pm
by alavelle12
Still in tear down mode for my 20v swap. Worked on pulling the rest of the heater box and everything under the dash (I'm going to be running just a half dash with no heat/ac). Also pulled the old 4ac broken cruise control and power steering lines. Still trying to decide if i'm going to b uy a manual rack or just loop the lines on my ps rack. Been working on cleaning up the engine bay with simple green as well, works amazingly! Trying to decide what color I want to paint my bay/stripped interior. Thinking a darker grey..
Posted: Sat Jul 04, 2015 12:12 am
by zem
cleaned engine bay, alternator went out...
Posted: Sun Jul 05, 2015 4:45 pm
by Demented86
I kicked the clutch..
Posted: Mon Jul 27, 2015 10:37 pm
by ejmr20
Finally got some brackets to mount my license plate on my kouki bumper
[/URL]
Posted: Tue Jul 28, 2015 8:23 am
by ritz
ejmr20 wrote:Finally got some brackets to mount my license plate on my kouki bumper
[/URL]
NICE!!! I just ended up drilling mine. Where did you get them?
Installed intake.
Posted: Sun Aug 02, 2015 8:23 pm
by ae90tuner
Posted: Mon Aug 03, 2015 5:08 am
by trigun402
Looks nice.
Posted: Tue Aug 04, 2015 9:31 pm
by tiprock
installed an thermostat controlled oil cooler setup on the hatch. #greddy #earls #setrab #8an
installed an exhaust on the coupe. #buddyclub
Posted: Thu Aug 06, 2015 8:05 pm
by BlueDeathTrap
Picked up a Borg Warner S366 for it (T4 .91 flange, marmon style outlet), and started figure out what I need to do to the intake for matchporting and proper flow.
Posted: Sat Aug 15, 2015 10:02 pm
by BlueDeathTrap
BlueDeathTrap wrote:Picked up a Borg Warner S366 for it (T4 .91 flange, marmon style outlet), and started figure out what I need to do to the intake for matchporting and proper flow.
Also debating tube framing the rear end, and hacking out the front strut turrets and replacing them with double wishbones up front and double adjustable afcos all around. And I've started my wheel hunt, 15s aren't going to cut it; so it's either 17s or 18s, offsets will depend on what the overall layout will be, widths will be WIDE.
Posted: Tue Aug 18, 2015 10:47 am
by morgan
