What did you do to your car today?
Be nice to others.
saiGone
Re: What did you do to your car today?
Postby saiGone » Tue Nov 04, 2014 8:13 am
Esenpai wrote:Swapped my oem ex mani and tvis mani and put that lame egr back on so I can smog my car. Need to get some new exhaust donut gaskets for the cat doe.
Advanced has those for the low-low
.TRD.TRUENO.
Postby .TRD.TRUENO. » Tue Nov 04, 2014 2:18 pm
Installed TRD Door stabilizers.
I made a quick review if you guys want to see.
ryun84
Postby ryun84 » Tue Nov 04, 2014 3:05 pm
.TRD.TRUENO. wrote:Installed TRD Door stabilizers.
Yes, please.
.TRD.TRUENO.
Postby .TRD.TRUENO. » Tue Nov 04, 2014 3:21 pm
Yes, please.
https://www.youtube.com/watch?v=YjANtdDiCkE
Cheers~
Glock30
Postby Glock30 » Mon Nov 10, 2014 11:05 am
I went camping for my birthday in the Angeles National Forrest. The cats on my Bronco are clogged and I need tires on the old pickup so guess which car got to go camping. Luckily it's a hatch. The carb wasn't too happy in the cold and altitude, but since it was only for the weekend I figured it wasn't worth adjusting.
1984 Toyota Corolla Sport SR5
1989 Ford Bronco Eddie Bauer
1968 Ford F250
ae86714
Postby ae86714 » Tue Dec 23, 2014 9:21 pm
Got my intake mounted finally. Also installed an iacv black off plate, not that you can really see it lol.
ejmr20
Postby ejmr20 » Wed Dec 24, 2014 12:23 am
^ Nice. Like the way you secured your intake. Did you also use a silicone 45 degree elbow from the afm to throttle body?
85 GTS Coupe
07 Sti RIP
Esenpai
Postby Esenpai » Fri Dec 26, 2014 2:22 pm
Had to bungie cord my exhaust up because the hanger snapped somehow 0__0
Esenpai
Postby Esenpai » Fri Dec 26, 2014 2:30 pm
Thanks for the heads up hah
Swift Magician
Postby Swift Magician » Sat Jan 10, 2015 1:34 am
Changed up my wheels.
(test fitting wheels in this picture so the tires are reversed)
Ig:4AGE.jp
cliqwe
Postby cliqwe » Tue Jan 13, 2015 5:05 pm
Happened within the last couple days but got my car back from paint, replaced the windshield and put most of the trim back in, got my wheels PC'd with new tires... next up is suspension and an alignment so I can mount them :) For now though I just stare at it through my window cuz I have HW :(
ryun84
Postby ryun84 » Tue Jan 13, 2015 5:10 pm
cliqwe wrote:Happened within the last couple days but got my car back from paint, replaced the windshield and put most of the trim back in, got my wheels PC'd with new tires... next up is suspension and an alignment so I can mount them :) For now though I just stare at it through my window cuz I have HW :(
^ Can't see the pics! Would love to see the new paint.
morgan
Postby morgan » Tue Jan 13, 2015 6:44 pm
Nice? Reminds me of my hatch last april. Staring doesnt help btw, lol
My turd of an 86
20v swapped 86 write-up
ryun84
Postby ryun84 » Tue Jan 13, 2015 7:21 pm
Oh the pics are working now. Nice color!
Morgan is right LOL! Don't stare. Cover the window and focus or nothing will get done!
Esenpai
Postby Esenpai » Tue Jan 13, 2015 7:29 pm
Resprayed my new SwangBiz bash bar gold. Image
Billy_Andrea
Postby Billy_Andrea » Thu Jan 15, 2015 8:09 pm
Installed my MOs with R888s
Esenpai
Postby Esenpai » Thu Jan 15, 2015 10:07 pm
Image installed my bumper lights that just came in. Next it to get them all wired correctly. You can see the golden swang peeking thru. (≧∇≦)b
Yuri
Postby Yuri » Tue Feb 03, 2015 10:05 pm
I put in some brand new in-box bumper lenses to replace the one I broke on the freeway hitting a truck tire, and then took it up to the mountains to really get in touch with what it means to own an AE86.
Clouds
Postby Clouds » Wed Feb 04, 2015 10:07 am
Yuri wrote:I put in some brand new in-box bumper lenses to replace the one I broke on the freeway hitting a truck tire, and then took it up to the mountains to really get in touch with what it means to own an AE86.
AweOfShe
Postby AweOfShe » Fri Feb 06, 2015 4:33 pm
Hey guys pretty new to posting here, been lurking for ages. Got my car a couple months ago, changed the rear main seal and the trans output shaft seal while I was in there. Changed the wires and plugs to NGK, changed the starter, and some smog related things and passed smog... and cleaned her up as well as I could. Everyone keeps talking to me about this car haha.
Anyway, it started to rain today, and I couldn't do what I wanted to (finish clay bar-ing the hood) - so I took her out sliding for a bit ^_^
The SR-5 is pretty capable, even with a whining rear end. Pretty sure my ring and pinion are bad as well as my bearings so I've been thinking about getting a spool. I looked up how to set the backlash and bearing preload. I could get the tools and everything for it, but I think I might just hold off to get a GT-S rear end since I need brakes too.
ritz
Postby ritz » Mon Feb 16, 2015 2:19 pm
Took it mountain climbing
Spotted this guy on the way up there
ejmr20
Postby ejmr20 » Wed Feb 18, 2015 12:52 am
Sweet Car Ritz ^. Replaced my slave and clutch master cylinder. Sore back after getting the four brake booster flange/nuts off from the inside of the car. So much better but very annoying task to say the least. Pic below is the booster moved out just enough to get the flange nut back on while balancing it on my two fingers :lol:
85 GTS Coupe
07 Sti RIP
Postby Deuce Cam » Wed Feb 18, 2015 3:55 pm
^If you slightly trim the nub at the end of that clutch master fastener there's enough room to get a ratcheting wrench on there without having to loosen the booster. I was even able to trim the fastener with a pocket hacksaw while everything was installed, but it was a pita.
idreamofdrifting
Postby idreamofdrifting » Fri Feb 20, 2015 11:11 am
woke up my sleepy 86.......
ae86714
Postby ae86714 » Sun Feb 22, 2015 9:34 pm
Cut out some patterns of this insulation stuff, I don't think it will do much for sound but I have high hopes for it helping with the heat. Only had time for a mock up:
racer555
Postby racer555 » Sat Feb 28, 2015 12:07 pm
Installed my exhaust today
Pretty damn loud, the rear silencer thing was missing from the box... Got another one coming so it won't be too bad since its my daily
Gino1X1
Postby Gino1X1 » Wed Mar 04, 2015 4:34 am
Just washed my wife's Camry... and guess what.... it rained!
Untill next week!!! <sheesh>
mideng
Postby mideng » Wed Mar 18, 2015 2:25 pm
Drovby gardens and a hoodrat rub my knob....
She said she loved cumrollas! Hoodrats rule
hachi-6 D0ri
Postby hachi-6 D0ri » Sat Mar 21, 2015 8:39 am
spent to much money on it today..and yesterday ....and i will probably tomorrow
If your not crashing .. Stop being a p**$y Go hard in the paint!
~Stig
AKCowboy
Postby AKCowboy » Sat Mar 28, 2015 7:23 pm
Well today i finally made my Levin "Legal" and also installed my new NRG Quick release/steering wheel.
Good Day :)
Return to “Fun Talk”
Users browsing this forum: No registered users and 26 guests
