What did you do to your car today?
Be nice to others.
SidekickChuck
Re: What did you do to your car today?
Postby SidekickChuck » Tue Apr 16, 2013 9:53 pm
Ramair uk eBay auction. Took a week to get to ca. Not bad.
They replaced the red uni filters. But I prefer the Ramair filters strictly for aesthetic reasons. The Uni filters probably filter more particles as a whole since they have multiple layers and oil.
2001 Carbon Black e39 M5
carbd7age
Postby carbd7age » Wed Apr 17, 2013 12:47 pm
Chuck how do those filters attach? I bought a RamAir box that covers both carbs and the back plate was inside out, so I flipped it and now the clips don't work.
Knockoff Crew member #0001
SidekickChuck
Postby SidekickChuck » Wed Apr 17, 2013 12:58 pm
These are just the simple foam covers that have 2 (smaller) holes per filter that you spread open and slide over the (in my case) ITB trumpets. The holes are small so you open them up with your fingers and slip on.
carbd7age
Postby carbd7age » Wed Apr 17, 2013 1:53 pm
This is the filter i have. I can't remember if I have a filter for a Ford Cortina or BMW 2002, whichever is spaced right for my carbs.
http://item.mobileweb.ebay.co.uk/viewit ... 0535007721
Ryusei_Date
Postby Ryusei_Date » Wed Apr 17, 2013 2:02 pm
I gave my AE86 a bad tank of cheap gas...the poor baby lunged the way up to my house in the last stretch, it's doing fine right now but I get the feeling I shouldn't do spirited driving till I can put better gas...lesson learned, never put 3.65$ gas in your iconic Japanese sports car!
my car: 1986 Toyota AE86 coupe
KonaTrueno723
Postby KonaTrueno723 » Wed Apr 17, 2013 7:22 pm
carbd7age wrote:This is the filter i have. I can't remember if I have a filter for a Ford Cortina or BMW 2002, whichever is spaced right for my carbs.
Couple choices on ramair filters right there,,,good info guys. Thanks!
For my car today: Got my AGX's..FINALLY!!
87 GTS Coupe
72 Blown 6-71 Pro Street Vega
SidekickChuck
Postby SidekickChuck » Thu Apr 18, 2013 10:38 am
Could you drill out new holes to the plate to mount the filter element securely? I almost got that unit to try and get it to fit my application, but thought why not get the foam only ones for ease of installing. I thought there wouldnt be any difference since its not plenum based.
carbd7age
Postby carbd7age » Thu Apr 18, 2013 5:57 pm
Well I pressed the clips out and tried to install them from the other side, but for some reason they never catch anymore. So I came up with a new plan: drill out the 3 clip-catch-holes in the filter itself, thread the holes, install 3 bolts from the inside of the filter facing outwards, then the 3 bolts would stick through the plate and I can sling some wing nuts on them to hold it. I haven't done it yet, but I haven't come up with a better solution, either. I should have bought the ones you have but oh well....
86_LeViN
Postby 86_LeViN » Fri Apr 19, 2013 5:01 am
Finally finish putting it back together after paint
sqznby
Postby sqznby » Sat Apr 20, 2013 6:10 pm
I didnt do anything to it, I used if for picking this up :D
3TC
Tranny
How I took it out, hah. Suckers heavy.
KonaTrueno723
Postby KonaTrueno723 » Sun Apr 21, 2013 3:01 am
^^^awesome hauler!
87 GTS Coupe
carbd7age
Postby carbd7age » Sun Apr 21, 2013 4:56 am
Lol AE86 work truck edition!
Michael E
Postby Michael E » Mon Apr 22, 2013 4:39 pm
Took the ae86 to the 2013 import alliance spring meet at the Atlanta Motor Speedway. I only saw 1 other hatch and 3 coupes :cry:
carbd7age
Postby carbd7age » Wed Apr 24, 2013 6:49 am
Started sanding my wheels. Finished the faces of two of them with 500 grit. Still need to do the lips, then go 1000 and 2000 before polish. Also have minor lip damage on the 2 7jj's. I'm using a small palm sander to get the oxidation and scuffs off with 220 grit. 500, 1000, and 2000 are all wetsand by hand. Keep tellin myself it'll be worth it when I'm done...
ae86-20v-black
Postby ae86-20v-black » Wed Apr 24, 2013 11:11 am
i blow a fuse from alternator, and now im charging my batery and working in the fuse and fan relay.
carbd7age
Postby carbd7age » Wed Apr 24, 2013 12:47 pm
Took my carbs off to inspect and yell at them. Found the front carb would shoot gas out with a good stream whenever I moved the throttle arm, rear carb not so much. Apparently it was "rebuilt" at one point and RTV was used liberally so much so that the check valves from the pump diaphragm to the jet body were gummed up and stuck. With the float chambers removed, the front carb dumps gas everywhere, the rear carb stayed dry. Float chamber level dropped every time I hit the throttle arm, not in the back. I have all the parts soaking right now, got to order some kits from Wolf Creek Racing now. *sigh* More money more problems.
revhappy86
Postby revhappy86 » Wed Apr 24, 2013 11:03 pm
EJ86 wrote:
M.fate wrote:Looked at it with disappointment in my lack of progress.... :(
Time and money is what most of us don't have, I know how you feel...
right there with you guys. time, money, and hard work will make for a great car tho!
carbd7age
Postby carbd7age » Sun Apr 28, 2013 5:49 pm
Busy day today!
Camry:
Oil change
Replaced EGR VSV
Corolla:
Bootleg camber plates
T3 hatch bar
T3 injector port plugs
Dropped carbs' small parts in cleaner bucket
Mounted bare carb and manifold
Found a sexy spot to mount regulator
Figured a way to mount the air cleaner
tiprock
Postby tiprock » Sun Apr 28, 2013 8:47 pm
cruised the canyons and couldn't keep up with a hyundai tiburon. :oops:
zenki levin hatch
kouki trueno coupe
JDMwhiteboy
Postby JDMwhiteboy » Mon Apr 29, 2013 4:50 pm
Got new jets for the side draft carbs. Was running way too rich and stepped down a lot. Going to try to install the throttle linkage tonight if I have daylight.
Forum whore
Postby Deuce Cam » Mon Apr 29, 2013 6:41 pm
I threw on some hayashi's that were collecting dust for a while.
KonaTrueno723
Postby KonaTrueno723 » Tue Apr 30, 2013 1:06 am
Tinkered around with my stereo today. Installed MB quarts..ran out of speaker wire tho' dammit!
87 GTS Coupe
McLevin
Postby McLevin » Tue Apr 30, 2013 7:31 am
Pulled my engine. I hate 4age's. 2nd ruined motor in months. Fuuuuu.
Zenki85
Postby Zenki85 » Tue Apr 30, 2013 8:02 am
McLevin wrote:Pulled my engine. I hate 4age's. 2nd ruined motor in months. Fuuuuu.
Get it a motor from a distributor mang, or you just ripping the streets!
TEAM 'CLASSIC
A 'CLASSICALIFORNIACAR
Mr.Fujiwara
Postby Mr.Fujiwara » Wed May 01, 2013 1:26 pm
after i get off work im going to pull the tomei cams out of my engine put stock ones back in then
pull the motor and sell it!!! gettin ready for my 20v
MUAHAHAHAHAHA!!!! :idea:
Old username: Charskiezz
20V BT: Traded For F20c Swap
SidekickChuck
Postby SidekickChuck » Wed May 01, 2013 2:39 pm
Mr.Fujiwara wrote:after i get off work im going to pull the tomei cams out of my engine put stock ones back in then
Which tomei cams are you pulling?
ae86-20v-black
Postby ae86-20v-black » Wed May 01, 2013 3:33 pm
i was working in my sister toyota tercel and when i go to the parts store wide open my 20v and a spark cable get stuck in a trotel and i almost have a heart attack... jajajja safe for now.
KonaTrueno723
Postby KonaTrueno723 » Wed May 01, 2013 10:04 pm
^^^Man that must've been an "OH' :shock: SH*T" moment! But seriously,route them suckers away
For my car today,,i installed my new LHD TRD floor mats
87 GTS Coupe
carbd7age
Postby carbd7age » Thu May 02, 2013 4:31 am
A buddy of mine brought his Civic to me at work, it was misfiring. He said he just did a tune up but couldn't tighten on plug because his socket wouldn't fit? How'd you do the other 3? Anyway I tightened down and it still was missing, same cylinder it felt like. I pulled the plug wire off and it had a hole in it and was grounding out the the head intermittently. He had a spare cap and wire set in the trunk so I changed it with the car running. Gotta love 2 minute fixes!
ae86-20v-black
Postby ae86-20v-black » Thu May 02, 2013 9:02 am
KonaTrueno723 wrote:^^^Man that must've been an "OH' :shock: SH*T" moment! But seriously,route them suckers away
i have accel universal wires from a v8 in my 20v microtech lt10 and individual coils. one of the cables jump and got stuck in the last 3 and 4 trotel but that every day hustle in my life....
Return to “Fun Talk”
