DIY widebody gas cap from OEM
marley4us
Postby marley4us » Sun Jun 30, 2013 4:53 pm
So I actually started some work on the AE86. getting the OEM Gas cap to fit the widebody
Remove the two screws with a screwdriver that hold the gas cap to the car
Found a piece of aluminum tubing. But you could use steel or probably even plastic lol. Then Found some longer bolts M5-.80x40 class 8.8 from lows ( i had in bucket of bolts) and cut the aluminum tubing to space it. I also used a washer to hold it in place. These size bolt fitted my gas cap perfect to space it to my origin 35mm over fenders, but it will very from car to car so measure lol
Then remove the lock that is attached to the gas cap with a 10mm socket.
removed
Get a piece of steel or aluminum ( i used aluminum since i had it, and its easier to form)
Bend it to the shape of the lock
Cut it down, and mark it where the bolt hole is
drill ur hole
test fit it, and measure for how far out you want the gas cap to close so its flush with the widebody
Drill you second hole larger so it will allow for the door lock to slip in
Bend it and adjust it, it may take a few trys but its easier to work with, and you can get it flush
Done :0) and practally free
1994 4runner (The truck)
carbd7age
Re: DIY widebody gas cap from OEM
Postby carbd7age » Tue Jul 02, 2013 9:04 am
I like the tape on the end of the ratchet! Presumably to prevent scratching?
Knockoff Crew member #0001
ga_goosh
Postby ga_goosh » Tue Jul 02, 2013 2:58 pm
wow i would do this if i ever did a wide body rolla. nice looks good
I <3 my AE86
4AG Manual
AE86 FSM
KonaTrueno723
Postby KonaTrueno723 » Wed Jul 03, 2013 12:31 pm
Nice..!
87 GTS Coupe
72 Blown 6-71 Pro Street Vega
SidekickChuck
Postby SidekickChuck » Tue Jul 09, 2013 3:57 pm
Time to find a new image host or upgrade Marley
2001 Carbon Black e39 M5
marley4us
Postby marley4us » Sun Jul 14, 2013 9:08 pm
pics are back
