4age hi comp block (7 rib)
Brendoninhawaii
Postby Brendoninhawaii » Tue Nov 19, 2013 11:37 am
looking for just the block for cheap, and someone willing to ship to hawaii, i know its a long shot, but why not just put an ad out there, for someone that wants to just get rid of it
ga_goosh
Re: 4age hi comp block (7 rib)
Postby ga_goosh » Thu Nov 21, 2013 6:34 am
are you looking for the squirter block 7 rib? i have a non squirter 7 rib from a large port if your interested
I <3 my AE86
4AG Manual
AE86 FSM
Brendoninhawaii
Postby Brendoninhawaii » Thu Nov 21, 2013 11:26 am
ga_goosh wrote:are you looking for the squirter block 7 rib? i have a non squirter 7 rib from a large port if your interested
does that block have the 10.3:1 compression as well? and is that the only one that will fit with a blue top head?
SlideSexy
Postby SlideSexy » Thu Nov 21, 2013 11:48 pm
Brendon, your looking for a 7rib with the oil squiters. from an AE92 GTS.90-91? If im correct.. I want the same block lol.
A non oil squirter 7rib is from a non SC AW11 MR2. (SC MR2 has like 8.0:1 c/r).
Its gonna cost like $300 to ship bro. (150lbs +\- a.few tens.)
ANYONE CAN BUY A NEW CAR. IT TAKES A TRUE ENTHUSIAST
TO BREATHE LIFE INTO AN OLDER ONE.
Brendoninhawaii
Postby Brendoninhawaii » Fri Nov 22, 2013 3:25 pm
SlideSexy wrote:Brendon, your looking for a 7rib with the oil squiters. from an AE92 GTS.90-91? If im correct.. I want the same block lol.
thanks bro, and yea...a boy can dream cant he haha
blackhmong85
Postby blackhmong85 » Fri Nov 22, 2013 6:32 pm
i have a hi comp block with oil squiters. $300 located in sacramento, ca
Brendoninhawaii
Postby Brendoninhawaii » Sat Nov 23, 2013 11:22 am
blackhmong85 wrote:i have a hi comp block with oil squiters. $300 located in sacramento, ca
Im from hawaii though so you have to factor in shipping, and slidesexy is from rhodeisland so again you have to factor in shipping
Postby yoshimitsuspeed » Sat Nov 23, 2013 11:44 pm
The block has nothing to do with compression. The only differences are going to be the squirters and a couple hole locations on the block. The NA largeport 7 ribs have a knock sensor blank but it's not tapped. The GZE 7 rib will have the knock sensor bung tapped.
Squirters are not valuable enough to go too far out of your way for. If you can find a healthy 7 rib anywhere on the islands your money would be better spent there.
People have done high reving builds and high power turbo builds without squirters. Unless you are building a race engine or boost monster I wouldn't worry about it.
Brendoninhawaii
Postby Brendoninhawaii » Sun Nov 24, 2013 3:35 am
yoshimitsuspeed wrote:The block has nothing to do with compression. The only differences are going to be the squirters and a couple hole locations on the block. The NA largeport 7 ribs have a knock sensor blank but it's not tapped. The GZE 7 rib will have the knock sensor bung tapped.
yea basically i wanted a 7 rib bottom, but its hard to find here, but i guess its not that important if i dont find one, thanks for your help
Return to “Want to BUY (seeking sellers)”
