Front spring insulator (#48157-12030)
Grant
Postby Grant » Mon Jan 25, 2016 2:14 pm
I went to Toyota to order these (I was able to order new rear insulators), and they told me they don't sell them anymore... :(
Does anyone have a way to get these? Thanks.
Grant
Re: Front spring insulator (#48157-12030)
Postby Grant » Tue Feb 02, 2016 9:11 am
Still looking for this.
Grant
Postby Grant » Sun Feb 21, 2016 4:07 pm
Bump... I will accept used parts as well if they are in usable condition.
Deuce Cam
Postby Deuce Cam » Sun Feb 21, 2016 4:42 pm
For this type of stuff you gotta scour the part out threads. I might have found some for you. Check #123 here: viewtopic.php?f=15&t=16620
FYI usually after decades of use the insulators are bonded to the spring top hats so maybe a 2 for 1 deal.
I don't know the seller, check with him to see if the insulators are intact.
dcnazario
Postby dcnazario » Mon Feb 29, 2016 1:33 am
I have a couple seating, lmk
just another rolla, keeping it alive.
85 Hachi - 87 Coupe
Grant
Postby Grant » Tue Mar 01, 2016 1:17 pm
Deuce Cam, thanks for the link. I have been browsing them when I can.
dcnazario, I Replied to your PM.
MtLemmon86
Postby MtLemmon86 » Fri Mar 04, 2016 9:37 am
I have the moog and import direct part numbers from oreillys if you have one by you, they should be able to order them.
Grant
Postby Grant » Sat Mar 05, 2016 10:39 am
MtLemmon86 wrote:I have the moog and import direct part numbers from oreillys if you have one by you, they should be able to order them.
Really? It's worth a try, so let me know the numbers. Thanks!
The issue I'm running into is all most AE86 folks care about is coilover kits, so there is no market for stock suspension parts. :(
Return to “Want to BUY (seeking sellers)”
