1991 Toyota Cressida 2JZ NA-T $6000
Posted: Thu Jan 02, 2014 3:00 pm
by LuckyLuciano
Contact Info: Email: ajanderson1718@gmail.com (347) 248-0468 text or call
Year: 1991
Make: Toyota
Model: Cressida
Color: Black
Mileage: 152,xxx
Transmission: Manual
Price: 6000.00
Description: Car is boosted by way of a 2jzge na-t setup on 2jzgte electronics. A list of modifications:
Engine
2jzge engine with stock hg and harness out of a 1st Gen gs300 with brand new valve cover gaskets, seals, brand new clutch fan (from a ls400), with the EGR removed.
Brand new radiator
SS power steering line
XM 91-92 engine brackets
Turbo setup
T67 turbo kit for a 2jzgte from driftmotion.com which includes:
3in downpipe, 50mm 4 bolt hks style wastegate (11psi spring), t67 turbo of course, 4in intake pipe with filter.
2jzge Ebay turbo exhaust manifold
-10an oil drain
-3 oil feed with -4 adapter
Coilpacks and Ignitor from a 2000 Lexus gs300
1jz/2jz Map sensor
440 injectors and resistor pack from a Mk3 Turbo Toyota Supra
2jzgte Auto Ecu and IAT
AEM wideband and Greddy Boost gauge
Drivetrain
W58 (non-turbo) transmission out of a '89 Supra along with driveshaft, pedals, and slave and master cylinders
2jz bellhousing and flywheel
ARP flywheel and pressure plate bolts
XTD 6 puck clutch disc and pressure plate
SS clutch line
Suspension
JIC front coilovers from a JZX81 (Toyota Chaser)
S13 swaybar links
New Driver side RLCA and axle
S13 Cusco Rear coilovers
Interior
Grey Cloth Interior
JDM Mk4 Supra 3-spoke steering wheel
Gauge Installation kit to replace clock
Bad:
Rear bumper is rotted underneath and passenger fender also has rot by the mudflaps. Sunroof glass has a crack but doesnt leak.
Car has awesome potential. Price is negotiable also.
http://i137.photobucket.com/albums/q234 ... 99630b.jpg
http://i137.photobucket.com/albums/q234 ... 6348f0.jpg
http://i137.photobucket.com/albums/q234 ... 802a8d.jpg
http://i137.photobucket.com/albums/q234 ... 9af5ec.jpg
http://i137.photobucket.com/albums/q234 ... 7a9364.jpg
