TW/FT:'91 Nissan 240sx Fastback-many upgrades!!!
Posted: Fri Nov 08, 2013 9:12 am
Recently picked this up mainly because I need a vehicle and this was the best one that was available at the time but initially I wanted a swapped f20c ae86 or good condition NB miata and seeing if anyone is willing to trade. Vehicle must be in comparable condition and cost or add cash on top. Located in San Francisco, Ca.
PARTS LIST:
Engine/transmission/drive-train:
1 S13 SR20DET redtop
2 Wiring Specialties S13 to S13 SR harness with Z32 MAF connector
3 Rebuilt bottom end, hone block, deck block (by G-Dimensions)
4 OEM piston rings
5 ACL bearings
6 All new engine gaskets
7 Tomei metal head gasket 1.2mm thickness
8 polished crank and full balance performed
9 ARP head studs
10 Brian crower valve springs and retainers (titanium)
11 NGK BKR 7 EIX spark plugs heat range 7
12 RS Enthalpy tuned ECU
13 S15 Spec R T28 (Garret GT2560R, GT28R)
14 S15 exhaust manifold gasket, multi-layered steel
15 T25/T28 reclocking adapters
16 OEM turbo in and out gaskets for compressor side
17 Earls motorsports stainless steel turbo lines (for SR20DET)
18 OEM oil drain return kit for GT28R
19 APEXi AVC-R Electronic Boost Controller
20 Deatschwerks 550cc injectors
21 z32 fuel filter
22 CFM Performance fuel pressure gauge port
23 Walbro 255 LPH fuel pump
24 Nismo adjustable fuel pressure regulator
25 Z32 MAF
26 Isis front mount intercooler w/ hotpipe
27 Greddy type-RS BOV (recirculated)
28 Greddy BOV recirculation fitting
29 Greddy aluminum BOV flange
30 3 inch elbow
31 Enjuku Racing O2 sensor adapter
32 3 inch downpipe
33 Custom exhaust piping by BRM exhaust
34 22” silverline resonator
35 Magnaflow muffler (Dual 3” beveled tips)
36 Circuit Sports polyurethane exhaust hangers
37 Piping pro aluminum intake w/ bungs for recirculation and oil bypass welded on
38 APEXi Dual funnel power intake filter 80mm for z32 maf (n62)
39 Greddy oil cooler sandwich adapter
40 Sweet performance -10 "Max-Flo" black nylon braided oil lines
41 Sweet performance NPT-to-AN oil cooler fittings
42 B&M oil cooler core
43 Circuit Sports aluminum coolant reservoir
44 Powered by max aluminum radiator
45 DiF dual fan controller
46 OEM dual Altima electric fans
47 Powered by max magnetic drain plug
48 Blitz Type 1 D1 Spec radiator cap (1.3 Bar)
49 Bings aluminum pulley set
50 Touge Factory insulative intake manifold gasket made from insulative PTFE
51 Custom under skid plate
52 Optima Redtop Battery (relocated to the rear)
53 HKS D1 oil filler cap
54 Nismo engine and transmission mounts
55 B&M short shifter
56 Redline MT-90 synthetic transmisison oil
57 DiF braided clutch line
58 Clutch dampening box bypassed for increased pedal modulation
59 ACT street/strip clutch kit (pressure plate, disk, throw out and pilot bearings)
60 S15 OEM Helical LSD
61 Nismo differntial bolts (12mm thread with 13mm stem)
62 4.64 final drive from 2002 xterra ring gear and pinion
63 New OEM differential gasket
64 Redline 75W90 gear oil for differential
Brakes:
65 OEM Z32 30mm 4 piston iron calipers, front
66 DBA 4000 rotors, 3000GT VR4 (320mm x 30mm), front
67 Zperformance caliper brackets, front
68 Project Mu B-force brake pads, front
69 Heavythrottle ss braided brake lines, front
70 OEM Z32 2 piston calipers, rear
71 Powerslot z32 rotors, rear
72 Project Mu B-force brake pads, rear
73 ProjectSilvia ss braided brake lines, rear
74 Z32 e-brake conversion
75 Z32 2+2 e-brake cable
76 custom e-brake cable adapter
77 Speed bleeders in rear
78 Z32 17/16 brake master cylinder
79 Motul RBF600 brake fluid
Wheels/Tires:
80 Gramlights 57 Maximum Shining Silver 17" x 9" +12mm, front (no tires)
81 Gramlights 57 Maximum Shining Silver 18" x 9.5" +12mm, rear (no tires)
82 Rays Engineering silver center caps
83 Rota Grid Gold 17" x 9" +42mm (x4) with 15mm spacer
84 Nitto NT-05 235/45/17
85 Muteki spline drive lug nuts
86 McGard Lock nuts
87 ichiba 5 lug s13 hubs with OEM bearings (front)
88 z32 rear 5 lug hubs with upper tabs (greater strength)
Suspension:
89 SPL tension rods version 2
90 Tein tie rods (inners and ends)
91 Stealth Custom Fab tension arm brace (like nismo power brace)
92 Rebuilt rack and pinion
93 custom high pressure power steering hose (USDM s13 to sr20det s13)
94 Energy Suspension rack and pinion bushings
95 Energy suspension front sway bar bushings
96 Energy suspension front end link bushings
97 Custom made 1 piece rear strut bar (no lateral play)
98 Powered by max rear upper control arms
99 SPL PRO V3 traction rods
100 SPL PRO V3 toe rods
101 SPL PRO V2 solid subframe aluminum bushings with 1/2" of subframe lift
102 Megan Racing Street series coilovers
103 Adjustable c-pillar bar
104 RPSport subframe brace
105 Energy Suspension polyurethane steering rack bushings, red
Exterior:
106 OEM kouki 180sx front bumper, side pieces and all OEM braces
107 OEM kouki 180sx lip (Highly desirable item; very difficult to attain)
108 OEM kouki 180sx position lights
109 OEM kouki 180sx turn signals
110 C West rep headlight cover vent
111 JDM side markers
112 OEM 180sx chuki sideskirts
113 GP Sports rep 3-piece spoiler
114 OEM 180sx kouki taillights
115 OEM kouki trunk lock (not installed)
116 OEM kouki taillight garnish in Kevlar, reads "RPS13"
117 fenders rolled professionally by BesTint
118 quarter panels rolled and pulled professionally by BesTint
Interior:
119 JDM gauge cluster for s13 SR20DET (original US odometer remained on car)
120 Gauge cluster chrome trim pieces
121 LED gauge cluster bulbs (superbrightleds.com) blue
122 ProSport 52mm (fuel pressure, boost pressure, water temp, oil temp, oil pressure)
123 gauge rings for better visibility in day
124 3-gauge pod over center console (custom mounting with stealth set screws)
125 Autometer gauge angle rings for 3-gauge pod
126 ATI EZ pod over steering column
127 HKS turbo timer type 0 with Volt meter
128 Redline goods leather shift boot (black w/ red stitching)
129 Redline Goods leather e-brake boot (black w/ red stitching)
130 Redline Goods leather arm compartment cover (black w/ red stitching)
131 Custom 240sx specific floor mat set: 4 pieces ((black w/ red 240SX lettering)
132 Nismo resin shift knob (aka butt plug)
133 RAZO aluminum pedals and foot rest
134 reupholsterd glove box to black (I was trying to remove the tan but keep the brown)
135 Powered By Max black spin turn/drift knob
136 Luxor LED dome light
137 s13 key trim light
138 Alpine CDA-105 head unit (ipod control thru head unit)
139 Pioneer speakers 4x6's
Ammenities:
140 LE hatchback model (brown interior/trunk removed but still available)
141 Power windows (fully functional)
142 Power locks (fully functional)
143 Rear hatch wiper (fully functional)
144 Sunroof (no leaks)
145 Lo-Jack System + Early Warning System (notifies by text/email/call, up to 5 people if car is moved)
Trades:
Ae86 coupe- f20c swap preferred, no levin front (plus cash if needed)
NB miata (plus cash if needed)
PARTS LIST:
4 OEM piston rings
5 ACL bearings
9 ARP head studs
21 z32 fuel filter
25 Z32 MAF
30 3 inch elbow
32 3 inch downpipe
Brakes:
Wheels/Tires:
86 McGard Lock nuts
Suspension:
Exterior:
Interior:
Ammenities:
Trades:
