AE86 For Sale near Atlanta
Steadyslidin33
Postby Steadyslidin33 » Tue Jul 09, 2013 2:32 am
This car is an 85 corolla GT-S hatchback. Clean Title. Original 4age motor with 136,000 miles. Motor has been compression checked and runs very strong. The car has been used for the last year and a half as my full time driver. Go to http://www.facebook.com/brian.dupont.98 to see pics of the car. I have the title in hand and I need to sell NOW.
$3000 o.b.o - NO TRADES.
Replaced: ( NEW = since I got the car a year and a half ago )
New Fuel tank - new one has baffles so it can be drifted.
Replaced stock suspension with used Coilovers front and back
-Height adjustable
-Camber Adjustable
-RCA's installed
New T3 Camshaft pulley
New Slave cylinder
New Master cylinder
New Belts
New Alternator
New Battery
New Adjustable Panhard bar (T3)
New Racing tie-rods (discontinued racing spec)
New Front rotors OEM
New Front Calipers OEM
New Front and back break pads
New Rear wheel bearings OEM
New Front wheel bearings OEM
New Braided Racing brake lines all around (Goodridge)
New Distributor cap
New Rotor button
New NGK wires
New plugs (Bosch)
Front Strut Brace - installed by previous owner
4 - 1 Race header - installed by previous owner (TRD..I think)
Custom exhaust - installed by previous owner
Tune-Up
Compression Check: 1=170psi, 2=175psi, 3=165psi, 4=165psi
Adjusted timing 30 to 24 for more low end power
I also took apart the entire front end body panels and replaced all of the brackets, bolts, screws, washers, clips. Rolled the front fenders. It was then sanded down, primed & painted flat-black in preparation for the wrap I was going to put on it.
Needs fixing:
warped rear rotors - I have some still in the box that I can give you with the car.
Leaking LSD - needs resealing
Guages kinda work - speedometer is ten below the speed you're driving, Tach works fine, oil pressure works fine, temperature works fine.
AC/Heat do not work
I will be in the Best Buy parking lot - exit 269 off of 75 North (about 8 miles outside of the perimeter). I'll be there on july 9th and July 10th at 8pm. If you are interested be there with cash in hand.
idreamofdrifting
Re: AE86 For Sale near Atlanta
Postby idreamofdrifting » Tue Jul 09, 2013 9:40 am
Steadyslidin33 wrote:This car is an 85 corolla GT-S hatchback. Clean Title. Original 4age motor with 136,000 miles. Motor has been compression checked and runs very strong. The car has been used for the last year and a half as my full time driver. Go to http://www.facebook.com/brian.dupont.98 to see pics of the car. I have the title in hand and I need to sell NOW.
-Height adjustable
-Camber Adjustable
-RCA's installed
New Slave cylinder
New Master cylinder
New Belts
New Alternator
New Battery
New Distributor cap
New Rotor button
New NGK wires
New plugs (Bosch)
Tune-Up
Needs fixing:
AC/Heat do not work
Very nice Hatch!
Let me help you with the pics!
riddleyo
Postby riddleyo » Tue Jul 09, 2013 9:06 pm
Still for sale?
