Car is located in San Gabriel Valley in California
- call/text me anytime to see the car 626-678-3794 charles
Pros
-2tc head 3tc block
-long tube headers with heat wrap
-2 Xxr 002 15x9 et 0 i have mounted with hankook ventus v12 evo tires 70%
- 2 centerline autodrag 15x9 et -24 one has crack with hankook ventus v12 evo tires 70% (tires not mounted)
-mutegi black chrome lug nuts
- 5 spd t50 transmission
- custom race exhaust
- oem trd bubble flares
- mr2 seats mounted
- i have the interior fully gutted but i still have all the pieces if wanted
- brand new radiator less than 400 miles
- brand new timing chain, timing chain tensioners, valve cover gasket, timing cover gasket, oil pan gasket, new spark plugs, new auxiliary fan 10 blade, new thermostat all maintenance was done with only 400 miles on it
-comes with extra fender cause current driver side has damage from previous owner.
-car goes perfectly in all gear no grinding in any gears
cons
-needs the female part of the seat belts
-needs the plastic gromet that goes on the link of the shifter but it is still driveable and still goes in all gears without any grinding
if you want another pair of the xxr 002 15x9 et 0 i can get a good deal
