Motor:
S13 Redtop SR20DET
Brian Crower 264 cams
ARP head studs
Cosworth Headgasket
SR20det to AE86 motor mounts
Top mount Turbo manifold
T25 turbo with braided lines
XS intercooler kit for sr20det
Intercooler piping
Aluminum multi core radiator
Greddy type S bov
Walbro 255 external fuel pump
HKS mushroom intake
SARD FPR
Custom downpipe
Custom Vband 2.5 exhaust
relocated battery to trunk
(gt28rs turbo not installed)
Drivetrain:
Custom one piece driveshaft
MA47 rearend
Exterior:
Jblood front bumper with quick release latches
Jblood rear bumper
Runfree style sideskirts
Carbon Fiber sideskirts (banged up and repaired)
Carbon FIber Seibun doors
Carbon Fiber hood with AeroCatch latches
Custom one off Carbon Fiber origin style fender flares front and rear
origin widebody front fenders
Origin widebody rivated rear fenders
East bear fiberglass hatch with built in wing with Aero Catch latches
lexan rear window
RX7 smooth mirrors
Trueno front badge
JDM corner lights LED converted
JDM redline tails with LED
Fog lights
Trueno mudflaps
Raybrig headlights with HIDS
Custom made SR86 Twin Cam Turbo OEM style door badging (not installed)
Custom Made SR86 Twin Cam OEM style door badging (not installed)
Trueno gold badge kit for whole car (not installed)
Interior:
Full interior grey
Privacy rear cover
Grey Recaro reclinable seats
Takata Harness
Dash Matt
Nardi wood steering wheel
Hand made wood Ebrake handle
Hand made wood shift knob
Hand made Saporo keg tap shift knob
HKS turbo timer
Greddy boost controler
Greddy Boost guage
NX1600 Digital Dash ( fuel gauge not wired, everything else works. I have a digital sending unit that needs to be installed)
Solex locks, needs finishing on install
Wheels:
Gold with chrome lip Enkie mesh front 15x8 -13, rear 15x10 -38
or
Replica Watanabe in gold with chrome lip 15x9 -15
Suspension:
K sport coilovers
50mm RCA
Cusco tri point front strut tower bar
Cusco tri point rear strut tower bar
A pillar bar
DIY panhard bar
6pt cusco/safety 21 cage needs to be welded in
MA47 rear sway bar needs bolt drilled so it can be attached
T3 power steering knuckles (need to be installed)
T3 Outer tie rods (need to be installed)
Poly Bushing kit (not installed)
Brakes:
Brembo machined mini cooper rotors
RX7 FC 4 pot calipers and adapter for the front Gold color
Steel braided used brake line all 5 (need to be installed)
Extra: (if my asking price is meet I will give you all the stuff I have in the garage for my AE86, I have a bit of things not installed)
GT28RS turbi Brand new
Steel braided brake lines all 5 Used
T3 power steering knuckles used
T3 outer tie rods used
Both sets of rims 15x9 watanabe replicas and 15x10 enkie mesh
Digital fuel pump sending unit
Poly bushing kit for the whole car
Cusco Cage 6pt needs welding in
Oil Cooler with braided lines and adapter
Carbon fiber semi repaired side skirts
J blood style side skirts
Bad:
The car is not finished by any means, so I would recommend towing it home or to a good shop to finish it off. It needs a paint job it is plasti dip on the CF doors, and rattle can on the body. The rear sway bar bolt hole needs to be drilled as a bolt broke off and the sway bar is not attached at the moment. It has a boost leak, not sure where from either a intercooler pipe or from the intake manifold gasket, I have BNIB intake manifold gasket. I have a bunch of steel braided lines and fitting for the fuel system you can have. The passenger seat needs a bracket made for it. driver side it bolted in. Driverside window needs adjusting. Solex locks need to be professionaly installed. The super cool NX1600 digital dash works but could use a custom bevel to cover it and make it look more OEM, and the fuel gauge does not work right now. I have a Digital sending unit, but it needs to be put in the tank. Tires are pretty old one loses air after a week or two, but they are old tires stretched on massive enkie mesh rims. Roll cage needs to bolted in. Once this car is buttoned up and painted it will be a monster! with a little work I was going to finish it and sell it after a season of fun for about 14k plus! but I have to let it go. I need the cash for other endeavors. trying to be honest about the car, so someone knows what they are getting into, it needs some love. but it will be epic once done. As someone said once "This will decimate all with some overnight parts from japan"
Tags are all up to date, car is smogged.
