So-Cal: 1976 Datsun 620 Truck Bullet Sides
Posted: Wed Jul 16, 2014 4:05 am
1976 Datsun 620
Clean Title
Use to be daily driven, got a new vehicle, need room, must go!
Located: So-Cal SGV area
ASKING: $7000, no trades what so ever. Register still September 2014.
Shipping available, but buyer has to schedule pick up date and manage all of the shipping stuff.
Engine:
L20 w/4 Speed
Just rebuilt the carburetor so everything runs good and all adjustments has been made
Runs great, all gears shifts smoothly!
Mallory Racing ignition coil
Full wire tuck done by the previous owner (battery has been relocated behind the seat)
Electric Fan
Stainless Steel Muffler with turn down tip
Interior:
Factory bench seat
Custom Black Carpet
Custom kick panels with two 6" speakers
Optional/Rare Datsun center console off of a 720 with Alpine head unit mounted
--Stereo works and sounds greats!
Nismo Shift Knob
Fully wired LED interior lights
Authentic Nardi Wood Grain Steering wheel with Polished center (just recently installed)
Exterior:
Needs a little work but overall everything is fairly straight! Was prepping for a paint job before running out of space
H4 Front head light conversion with HID
Solex Locks
Suspension:
Rear 4" lowering blocks
Wheels:
16x8 Rota Grids
Falken Ziex Tires
1" Wheel adapters
Brakes:
Wilwood Enormous Aluminum 4 piston calipers (43.75mm pistons)
12 inch CNC drilled, slotted, vented, Zink plated, and machine balanced rotors
DOT approved custom fabricated steel braided brake lines
Custom fabricated T6061 aluminum brackets
Wilwood brake pads
Wheel and brakes were installed less than 100 miles ago/2 months ago. The brake and wheel set up alone cost over $2100!!
Also have a lot of parts that will be included with the truck! A lot of new parts for restorations, hopefully the new owner will finish restoring it. There's also a lot of spare parts!
Complete brand new rubber kit, which consist of:
-Front Windshield Molding/seal
-Rear Glass Molding/seal
-Left Door seal
-Right Door Seal
-Left Door Channel Felt
-Right Door Channel Felt
-Left Door glass squeegee
-Right door glass squeegee
-Shift boot
-Antenna
Brand new OEM Front Grill Badge
Brand new OEM left and right Datsun badge for fender
Brand new JDM bumper Lights (clear)
Brand new passenger side door hinges (current door hinge has some welds on it from the previous owner, it opens and closes fine, just bother me that there's a slight resistance when the door is almost closed from fully open).
Spare parts:
Smog stuff that was removed
Drum front brake parts
Steering wheel
Passenger Fender
Gauge bezels x 3
Fan+Fan Clutch
Misc small items
Stainless Window Visors
The bad:
-Cracked dash pad (have a custom dash cover that is currently on there)
-Needs paint
-There's a rot spot on the truck bed close to the cab on the driver side (this is the only rot, everything else is surface rust).
-Solex needs to be installed correctly
This is a 38 year old truck that is unrestored, so there are usual wears from being age for so long. Expect the usual stuff on a classic, such as surface rust, minor dents and dings, the smell of gas from the carb, etc etc. If you've never owned a classic before, you might not understand what it takes to touch and drive it a certain way.
Pretty much this truck is a driver and it will take you around and such. The plan is to restore it, which is why all of the brand new parts are also sold with the truck. All you would need to do is a little bit of body work and paint and you're good to go! If you want the engine bay to be cleaner, then you can fill the holes and paint the engine bay for a even better look!
EMAIL: ezpunkbz@gmail.com, if you're serious leave me your phone number and I'll call you when I get a chance.
Clean Title
Engine:
L20 w/4 Speed
Electric Fan
Interior:
Factory bench seat
Custom Black Carpet
Nismo Shift Knob
Exterior:
Solex Locks
Suspension:
Wheels:
16x8 Rota Grids
Falken Ziex Tires
1" Wheel adapters
Brakes:
Wilwood brake pads
-Left Door seal
-Right Door Seal
-Shift boot
-Antenna
Spare parts:
Steering wheel
Passenger Fender
Gauge bezels x 3
Fan+Fan Clutch
Misc small items
The bad:
-Needs paint
