FS: 1985 Corolla GTS (San Mateo, CA)
smaq
Postby smaq » Fri Jun 20, 2014 11:20 pm
PLEASE USE EBAY TO CONTACT ME. Thanks.
1985 Toyota Corolla GTS (AE86) with a CLEAN TITLE. It has only been daily driven with regular maintenance. It has been sitting for about a year, but still starts up right away and runs strong. It should pass smog with an appropriate warmup, however, I would recommend a tuneup with a new timing belt as it has never been changed since I have owned the car. The frame is straight and the body has no rust. The previous owner did repaint the car, which has since faded. There is no noticeable overspray.
This model does NOT have a sunroof or AC.
Additions:
Illegal Garage Clutch
Kaaz 2-way LSD
Slotted rotors
Steel brake/clutch lines
14" Konig Rewind Wheels with Kuhmo Solus KH16 tires (85% tread)
Suspension recently aligned
Issues:
The temperature lever for the climate control is jammed, i.e. no heat.
Ripped upholstery
Transmission fluid spilled on backseat carpet (smells a little funky)
Ebay listing: http://www.ebay.com/itm/171363946951?fo ... &viewitem=
luii4g63
Re: FS: 1985 Corolla GTS (San Mateo, CA)
Postby luii4g63 » Mon Jun 30, 2014 7:50 pm
Still have the corolla for sale?if so pm me!!!!!
idreamofdrifting
Postby idreamofdrifting » Mon Jun 30, 2014 9:58 pm
luii4g63 wrote:Still have the corolla for sale?if so text or call 3two3899seven054
MRpazMR
Postby MRpazMR » Wed Jul 02, 2014 10:01 pm
Is this still for sale? Ebay bid has closed
