I am the 3rd owner since 2011. I'm located in Cerritos and can show the vehicle during the week after 7PM and weekends. No test rides without cash in hand.
Vehicle details:
- 5 speed manual. Transmission shifts smoothly without grinds or whine.
- Little over 200k miles on the chassis.
- On its second motor. I replaced the motor at 170k with a lower mileage 2.2L (roughly 80k). Have paperwork for the motor swap. The following items were done during the swap; replaced Timing belt, Water Pump, Tensioners, Distributor Coil, Spark Plugs (NGK Iridiums) and Wires (NGK Blue), All Valve cover Gaskets.
- No Rust damage or accidents. There is one soft dent on the passenger fender from a kid throwing a ball but it can be pushed out easily. Paint isn't cracked in that area.
- Paint is fading on the roof and there are typical nicks & chips in the paint. The Subaru emblems were stolen off the rear hatch and there are scratch marks (during the previous owner’s possession). There is a slight dent on the rear passenger c-pillar by the hatch glass.
The car includes the following parts:
* Kartboy Short Shifter & Bushings
* RS (white) Gauge cluster, will include the original OBS cluster.
* TOKICO D-Spec (JDM) Shocks, adjustable damping.
* 2002 WRX Springs
* 2004 WRX Front and Rear Brakes
* Stainless Steel Brake lines Front/Back
* 2006 STi Rear Sway Bar
* 2004 WRX Catback Exhaust
* Clear side markers
* Clear corner lamps
* Silver RS Hood (minor bend at the corner from previous owner)
* Transmission and Rear Differential is from 2001 RS
* New Radiator
* Wagon Cargo cover and original Subaru Cargo tray
* Subaru Keyless Entry
* Exedy Street Clutch and Flywheel bearing replaced
* Whiteline Upper Front Strut bar
* Whiteline Upper Rear Strut Bar (For Wagon)
* JDM GF8 rear tail lamps
Additional work done & parts added:
* Replaced the motor at 170k with a lower mileage 2.2L (roughly 80k) w/ details below.
* Replaced all four wheel bearings
* Replaced the TPS
* Replaced the carpet (dark grey from an RS)
* 2.5RS floor mats
* 2004 WRX front seats (Will knock off $200 if you supply your own seats)
* Factory Subaru 6 disc radio from a WRX
* White Rota Slipstreams 16x8 +48 with 205/50-16 Firestone tires (need replacing)
* Will include a lower mileage power steering pump as the current has a slow leak.
I have a ton of parts for the car that I will be selling separately in a separate post but the buyer will have first dibs.
* Black Ver. 2-4 Front Bumper with fogs, turn signal and bumper beam. Includes one extra passenger side bumper light that has a cracked mount but easily fixed. $380
* Primered JUN replica front lip, rare & clean. $350
* Black RS grill, clean. $100
* Silver OBS wagon spoiler with mounting brackets, clean. $120
* Blue OBS wagon spoiler without brackets, needs repaint. $60
* JDM Roof Rails, corner has a small crack. $160
* Silver RS sideskirts, $100
* OEM carbon fiber dash kit, $20
Front
Front ¼ driver
Side
Rear ¼ driver
Front ¼ pass
Rear ¼ pass
Rear
Cluster
Dash
Trunk
Engine
Front interior driver
Rear interior driver
Front interior pass
Rear interior pass
