NorCal 1982 Volvo 242 Turbo FT/FS
aprophet13
Postby aprophet13 » Sun May 11, 2014 1:39 pm
FS/FT: 1982 Volvo 242 Turbo, 5 speed, RWD, coupe
Asking $6,000 OBO
here is my build thread on stance works if you want more pics:
http://www.stanceworks.com/forums/showthread.php?t=47877&highlight=olga
Redwood city area 94065 but if you're serious we can work something out if you're far.
Contact info: 650-644-8454 or adrianprophet95@gmail.com
Asking for 6000 OBO but probably won't get that so if you have any trades I'm open, just has to be RWD, Manual, and drivable. I can add cash on my end too.
Modifications include-
engine/trans:
B21ft 2.1L turbo 4 cyl
15g upgraded turbo
MBC set to 10 psi
90+ exhaust manifold
M46 4 speed manual w/ electronic overdrive(5th gear)
FMIC
full 3" with cat and muffler (1000)
upgraded fuel pump from 740 turbo
Suspension:
Adjustable torque/panhard rods w/ poly bushings
poly bushings in rear trailing arms
welded diff
cut springs rear with bilstein HDs
RSI coilovers up front 300# springs and bilstein short strut HDs (1200)
camber plates- not installed yet
interior:
2x recaro pole positions w/ status racing 4 pt harnesses (2000)
purple grip royal steering wheel (can include black Momo wheel)
ipod plugin and 12" sub
bolt in 4pt half cage (1000)
exterior:
'93 850 lower bumper half
rolled/pulled fenders
16x7/8 et 0/-10 widened steelies with stretched 175/50 all around (1000)
Late 82+ bumpers
trim delete
quad square headlights but also have the dual round set up I can include
Maintenance:
Brakes redone 18 months ago- new calipers, prop valve, rotors (800)
Brakes bled after coil over install 4/14
oil changed
E-fan
new plugs and wires
timing set
**PASSED SMOG in 4/14**
goods:
reliable has never left me stranded
tons of maintenance parts have recently been looked over
with this current setup it will pass smog no problem
manual
RWD
turbo
bads:
wipers are intermittent
right rear turn signal is out
slight oil leak from right side of bay, haven't pin pointed it
paint is bad in a few places w/ a little surface rust.. car is 32 years old its expected.
text me if you have any questions/offers/trades
thanks,
Adrian
