BEST OFFER gets her. have 7k as my baseline offer at the moment.
Looking to sell whole, not willing to part-out at the moment.
Here is a link to the photo gallery (build page on Club4AG is useless since it has no working pictures): https://postimg.cc/gallery/3i2kq3zby/
Here is a list of parts purchased, refreshed, or modified. Either using Quality OE parts or proper quality aftermarket parts. Was designed to be a handling machine.
4AGe and T50 with propshaft are out. Needs Head Gasket. Brakes need to be bled. Needs alignment.
Have new OEM top rad support, with straight side supports that will include with sale.
Parts not listed/pictured are not included unless otherwise noted.
Labor not priced.
AE86 PARTS (ON CAR)
-JDM Leather Stitched Steering Wheel, W/Boss adapter (Black) $400.00
-New Reman Disty $104.33
-Traction Bracket (Jubride) $169.90
-Valve Cover Gasket (Japan) $37.93
-OEM Rear Axle Seals $13.00
-OEM Rear Axle Bearings $115.86
-OE Brake Master Cylinder $89.95
-Megan Tie Rods $106.99
-TRD Engine Mounts $199.99
-JDM Air Con Switch/Panel (no cables) $150.00
-Cruise Control Wiper Stalk $99.00
-Aux Air Valve Gasket $5.00
-Muteki SR35 Wheel Nuts $56.99
-OEM Light/Wiper Dial Switch $38.00
-Poly Rear Panhard Rod to Axle Bushing $25.91
-Brake Rebuild/Powder Coat (EVO grey)
-Front Brake Caliper Dust Shields $60.00
-Phase 2 Slotted/Drilled Front Brake Rotor $112.51
-Phase 2 Slotted Drilled Rear Brake Rotor $112.51
-OE Toyota F/R Caliper Rebuild kit(+labor), Powder Coat, SS lines, HAWK HP Pads $1,000.00
-Cusco Lower Front Tension Rod (116 485 A) $119.00
-Cusco FRONT sway bar Fixed 23mm(vs. stock 21mm -130% increased)[116 311 A23] $267.00
-Cusco REAR sway bar Fixed rate 20mm dia.(vs.16mm-156% increased)[116 311 B20] $254.00
-Cusco Formula Link Jr. - Half Pillowball and Bushing End Control Arms (upper)
*4-Link consisting of metal pillowball end on one side and bushing on the other end. (adjustable length) $440.00
-Cusco Formula Link Jr. - Half Pillowball and Bushing End Control Arms (lower)
-Cusco Lateral Rod (Panhard Rod) Rubber Bushing End Lateral Rod
*Adjustable lateral rod with rubber bushing ends (+15~-10mm) [116 466 A] $200.00
-OBX Pillow Ball Tension Rods (Adjustable) $360.00
-OEM Lower Front Arm RH $190.81
-OEM Lower Front Arm LH $198.81
-OEM Hub Sub-Assembly Front Axle $149.50
Custom Short Stroke Coilover Shock Conversion:
-Short Stroke cut/welding service (with Satin Black powder coat)
-Front TRD adjustable race shocks $475.00
-Rear TRD adjustable race shocks $325.00
-Cusco RollCenterAdjusters (RCAs, 30mm), $200.00
-Swivel bearing upper high hat mounts (with needle bearings), 65.00
-Cusco Pillow Ball Mounts (with camber adjustment), $280.00
-BGRS/Swift Rear 4.5KG springs with Adj. Height Fortune Auto perches $385.00
AW11 Manual Rack conversion:
-Intermediate shaft from MKIII Supra $85.00
-Manual Rack adapter bushing $45.00
-Rebuilt AW11 Manual Rack $115.00
-Conversion Tie-rods $50.00
Lightweight 15x7 Konig Alloy Wheels With BF Goodrich Sport Comp-2's $1,100.00
TRD Headers With Axle-Back JASMA JDM exhaust (Mid pipe is cracked, and leak). $950.00
Rear wiper arm, motor, reservoir, etc. $100.00
All parts have less than 10-20 miles on them.
Some more parts I'm sure I'm forgetting, but, that's the gist of it.
Clean Florida Title in my name. No rust. Car was from Texas.
Please e-mail for faster response:
thedesertfox117@hotmail.com
Thank you!
