These units are fully triangulated and fully gusseted to eliminate flex. We even gusseted the end brackets at all points to improve stiffness. We have also extended the forward mounting point as far down the chassis as possible, so that it fully supports the strut towers.
These are very easy to install. Simply bolt up, drill two holes and use the special tool provided to mount the two forward bolts. The tool stays in place on the inside of the fenders and works as a support bracket for the backside of the bolts. Slight clearancing of the chassis edge is required, but only takes about 5 minutes or less. These will not interefer with factory or aftermarket fenders.
These will help eliminate chassis flex and suspension deflection providing more precise and responsive handling feedback.
All brackets are laser cut for a super precise finish and alignment.
Available in nearly indestructible fine wrinkle black powdercoat.
Includes all stainless mounting hardware. $195 the pair.
Contact us at:
Techno Toy Tuning
4211-A Business Dr.
Shingle Springs, CA 95682
(530)672-8600
www.TechnoToyTuning.com
