NonStopTuning Brake Master Cylinder Stopper
Posted: Mon May 06, 2013 9:04 am
The purpose of all MBC Stoppers is to increase brake response by re-applying the force exerted by the driver on the brake cylinder back to the brake cylinder. This is accomplished by reducing firewall flex that occurs as the brakes are applied. While there are different methods of accomplishing this, the NonStopTuning BMC Stopper is a prime example of a practical means of improving brake response, in an affordable way.
The NST MBC Stopper provides more solid brake response, very noticeable on late braking into corner apexes. Aesthetics, strength, weight, and added adjustability have all been considered in order to accomodate slight differences from one AE86 to the next in regards to the exact location of the OEM BMC, since no two AE86 chassis are exactly alike. This piece mounts to the strut tower using 10mm bolts in pre-existing bolt holes.
Each NST MBC Stopper is hard anodized for exceptional strength and durability.
Available in your choice of Red or Graphite Gray.
