BC Racing Coilovers - Full Sets With Spindles, Front / Rear
NonStopTuning
Postby NonStopTuning » Fri May 03, 2013 7:47 am
http://vimeo.com/41261151
ORDER ONLINE, SHIPS TO YOUR DOOR: http://nonstoptuning.com/BC/pBCcoilovers.html
Coilovers that strike the best balance between performance and cost. We have designed all the most popular and essential features into our coilovers while keeping the end price down for the consumer. Whether you are cruising down the street, enjoying your favorite twisty mountain road or tearing up a race track, we have a coilover system for you. You get to choose your spring rates; either keeping the recommended spring rates or selecting from our available stock. We even install the springs for you so you don't have the hassle of doing it in your garage or living room. As an added service, if you choose spring rates 4k higher or lower than the recommended setting we will revalve the dampers for you. We beleive you shouldn't have to pay a premium price for a quality coilover system.
FOR THE AE86 COROLLA:
Front + Rear Full Set With Spindles
Front Only With Spindles
Rear Only
Also available for other makes and models.
Mono Tube shock design
30 Way adjustable
Adjustable camber plates
Separate full length height adjustable
One year warranty
Rebuild services available in the U.S.A.
Custom spring rates and valving available
BC RACING SUSPENSION NOW AVAILABLE WITH SWIFT SPRINGS AS SPECIAL ORDER ITEMS!
** Swift Spring Technical Advantages
-Swift proprietary material along with advanced cold winding process allows Swift springs to be manufactured using a thinner wire diameter with fewer coils making the springs the lightest magnetic metal springs available on the market.
** Swift Accuracy
-Swift Metric Coilover springs feature the highest linearity of any spring out there. Along with the widest stroke range possible, the springs stay linear throughout MORE of the usable stroke range compared to anything else out there. Swift guarantees the spring rate accuracy to be +/- 2% within the advertised spring rate!
** Industry leading spring response
Swifts superior spring compression speed responds much quicker over undulating road surfaces so the tires have a lesser tendency to skip. This enables the tire to stay in contact with the road, improving traction and helps keep tire temperatures down.
Please contact NonStopTuning for availability and special pricing.
NST - NonStopTuning
www.NonStopTuning.com
Last edited by NonStopTuning on Wed Aug 07, 2013 2:25 pm, edited 2 times in total.
MIKE @ NST
EST 2005
NonStopTuning
Re: BC Racing Coilovers - Full Sets With Spindles, Front / R
Thanks all!
Order Online, Ships To Your Door:
:mrgreen:
MIKE @ NST
EST 2005
minnesota86drfter
Postby minnesota86drfter » Fri May 03, 2013 11:47 am
Free bump- been rocking BC coilovers on ae86 2 years now. Only issue I had was T3 rca. Just tell T3 and they will fix it.
NikNes
Postby NikNes » Fri May 03, 2013 7:33 pm
Is the rear spring on the shock or in the stock location?
NonStopTuning
Postby NonStopTuning » Sat May 04, 2013 2:07 pm
minnesota86drfter wrote:Free bump- been rocking BC coilovers on ae86 2 years now. Only issue I had was T3 rca. Just tell T3 and they will fix it.
THANK YOU :mrgreen:
And yes, you can to custom T3 or you can use the RCA that is included with the current BC BR Kit!
MIKE @ NST
EST 2005
NonStopTuning
Postby NonStopTuning » Sat May 04, 2013 2:09 pm
NikNes wrote:Is the rear spring on the shock or in the stock location?
The rear springs are in the OEM location.
We strongly feel this is the BEST coilover kit in this price range for the AE86.
And we've had experience with a few different kits over the past few years.
Two Thumbs Up!
MIKE @ NST
EST 2005
NonStopTuning
Postby NonStopTuning » Mon May 06, 2013 9:10 am
Get an awesome coilover kit for your car this month, and get something awesome for yourself!
MIKE @ NST
EST 2005
NonStopTuning
Postby NonStopTuning » Mon May 20, 2013 10:36 pm
Thanks all!
MIKE @ NST
EST 2005
NonStopTuning
Postby NonStopTuning » Fri May 24, 2013 7:30 am
Lowness for your car, Fatness for your wallet!
MIKE @ NST
EST 2005
NonStopTuning
Postby NonStopTuning » Mon May 27, 2013 9:27 pm
One more week!
MIKE @ NST
EST 2005
NonStopTuning
Postby NonStopTuning » Fri May 31, 2013 12:26 am
Thank you ladies and gents for the recent inquiries :mrgreen:
MIKE @ NST
EST 2005
NonStopTuning
Postby NonStopTuning » Wed Aug 07, 2013 2:24 pm
BC RACING SUSPENSION NOW AVAILABLE WITH SWIFT SPRINGS!
** Swift Accuracy
Please contact NonStopTuning for availability and special pricing if you want Swift springs added to your kit.
NST - NonStopTuning
MIKE @ NST
EST 2005
NonStopTuning
Postby NonStopTuning » Tue Aug 20, 2013 4:32 pm
Members with BC BR Kits, feel free to post your photos, reviews, etc. in this thread.
MIKE @ NST
MIKE @ NST
EST 2005
NonStopTuning
Postby NonStopTuning » Thu Oct 17, 2013 3:08 pm
:mrgreen:
MIKE @ NST
EST 2005
SlideSexy
Postby SlideSexy » Sun Oct 27, 2013 9:07 am
Dads hatchback and my coupe both have BC Racing Coils!
Also his IS300 has them too! Best bang for buck in any car!
ANYONE CAN BUY A NEW CAR. IT TAKES A TRUE ENTHUSIAST
TO BREATHE LIFE INTO AN OLDER ONE.
NonStopTuning
Postby NonStopTuning » Thu Oct 31, 2013 6:25 pm
SlideSexy wrote:Dads hatchback and my coupe both have BC Racing Coils!
Awesome! Definitely very true :mrgreen:
MIKE @ NST
EST 2005
NonStopTuning
Postby NonStopTuning » Tue Nov 05, 2013 8:50 am
Available for delivery!
MIKE @ NST
EST 2005
DJManila
Postby DJManila » Sat Nov 16, 2013 11:00 am
how much would it be if swift springs were used?
Formerly known as seanperia
ZensokuD1
Postby ZensokuD1 » Mon Nov 18, 2013 9:48 am
Same questionas above.
NonStopTuning
Postby NonStopTuning » Thu Nov 21, 2013 1:10 pm
DJManila wrote:how much would it be if swift springs were used?
ZensokuD1 wrote:Same questionas above.
Thanks for the inquiry guys.
The swift upgrade usually adds about $150.00 to $300.00 depending on a few factors like, front only, front + rear, etc.
Please email us when you're ready to pull the trigger and we'd be happy to give you a full quote and answer any/all questions.
Many thanks!
MIKE @ NST
EST 2005
NonStopTuning
Postby NonStopTuning » Mon Nov 25, 2013 6:30 pm
Let us know if you need an awesome set of coilovers :mrgreen:
MIKE @ NST
MIKE @ NST
EST 2005
NonStopTuning
Postby NonStopTuning » Thu Dec 05, 2013 7:01 pm
MIKE @ NST
EST 2005
herro
Postby herro » Fri Dec 06, 2013 12:24 am
Can I get a quote for BR Set with Swift springs for front and rear 8/6kg are you able to get greddy as well?
98281
NonStopTuning
Postby NonStopTuning » Mon Dec 09, 2013 12:38 pm
herro wrote:Can I get a quote for BR Set with Swift springs for front and rear 8/6kg are you able to get greddy as well?
98281
Hello herro!
The swift upgrade, front+rear adds about $300.00 to the total, any spring rate you'd like.
Shipping is on us, no extra charge there. Please email info@nonstoptuning.com when you're ready.
We offer multiple brands, and actually used to use Greddy coilovers on the NST AE86, but I honestly feel the BC is a better option all around, and is what we use on the NST AE86 now.
Thank you, best of luck with all your projects!
MIKE @ NST
MIKE @ NST
EST 2005
NonStopTuning
Postby NonStopTuning » Mon Apr 21, 2014 9:14 am
Anyone else?!
:mrgreen:
MIKE @ NST
EST 2005
saiGone
Postby saiGone » Wed Apr 23, 2014 11:46 am
quote shipped to 20175. Full set. With or without Swift package.
Thank you!
NonStopTuning
Postby NonStopTuning » Fri Apr 25, 2014 7:34 am
saiGone wrote:quote shipped to 20175. Full set. With or without Swift package.
Thank you!
Please select the kit you are interested in and the website will take care of all the rest for you...
Many thanks!
MIKE @ NST
EST 2005
mesh on my rolla
Postby mesh on my rolla » Fri May 02, 2014 6:08 am
How much for a full set with spindles shipped to 92880 and 3 piece kit of lite weight pulley set for an SR20 in blue? (I do not need the P/S pulley)
Thanks
Follow me on instagram = mesh_on_my_rolla
NonStopTuning
Postby NonStopTuning » Fri May 02, 2014 8:30 am
mesh on my rolla wrote:How much for a full set with spindles shipped to 92880 and 3 piece kit of lite weight pulley set for an SR20 in blue? (I do not need the P/S pulley)
Thanks
Hey bud!
Please email us and we'll get you going :mrgreen:
Much appreciated!
MIKE @ NST
EST 2005
lancerer
Postby lancerer » Mon May 05, 2014 7:22 pm
Sent you a pm, Thanks ,Lance
