AE86 Carbon Fiber Drive Shafts (4 models now available)
gaijin_rokurunner
Re: AE86 Carbon Fiber Drive Shafts
Postby gaijin_rokurunner » Thu May 02, 2013 1:12 pm
Carbon fiber shafts for the altezza J160 tranny using the LEEN kit now available for order...hopefully soon will be finalizing carbon shafts for those running S2000 f20 engines using JSP mounts also!
phanist
Postby phanist » Fri May 03, 2013 5:00 am
GAIJIN is this the reason why u still have that j160 with leen box laying in your garage?.. waiting for the CB drive shaft LOL
gaijin_rokurunner
Postby gaijin_rokurunner » Sat May 04, 2013 4:42 am
Took me a while to mock up and get the correct measurements...i wasnt in a rush since my engine is not finished yet...but since im still waiting I figured i would get under there and finally get it sorted.
KonaTrueno723
Postby KonaTrueno723 » Thu May 16, 2013 12:03 am
Pm sent!
87 GTS Coupe
72 Blown 6-71 Pro Street Vega
phanist
Postby phanist » Thu Jun 13, 2013 4:00 am
thank you super gaijin
i just install my CB drive shaft it look beautiful and feel even better driving it.... feel pretty smooth...i really like it.....measure same length as my stock shaft... it fit nicely .... love it
thank you again
Jesse
Postby Jesse » Sat Jul 13, 2013 10:24 pm
Here's mine, out of the box and awaiting installation. Bump for an awesome product and a great seller!
Carthik
Postby Carthik » Mon Jul 15, 2013 2:05 am
Nice product! I have a few questions.
What's the benefit of the aluminum yoked version? I'm assuming it's lighter weight and better corrosion resistance?
How much lighter is the 2.75" shaft with the aluminum yokes vs the steel ones.
Are they stronger/weaker than steel?
Are the steel versions painted or powder coated? Any finish to the aluminum yokes or are they bare unfinished?
At what RPM do the 2.75" carbon shafts become unstable?
Thanks,
Carthik
1986 Toyota Trueno GTV
1988 BMW M3
1990 Nissan Skyline GT-R
1990 Honda Civic DX
1989 Yamaha YSR 80
2003 Derbi GPR 50 R
ritz
Postby ritz » Tue Jul 16, 2013 8:32 am
Do you have to run an adjustable 4-link with the carbon shaft? I'd like a carbon shaft, but keep OEM 4-link with ES bushings.
My car is only lowered about 2".
gaijin_rokurunner
Postby gaijin_rokurunner » Tue Jul 16, 2013 11:39 am
Aluminum version only comes in 3inch diameter, the purpose is to provide a bigger stronger shaft but keeping the weight the same as the 2.75 diameter shaft...finished is just the normal aluminum and rated at supporting 800hp . Steel has a black finish to them and can support 14500 rpm.
Ritz the shaft will fit but i cant predict what type of effect it would have on your car in regards to vibration due to in correct pinion angle...i wouldnt suggest it could be all that bad being off some but i do recomend adjustable 4 link .
Carthik
Postby Carthik » Sat Jul 20, 2013 6:20 pm
Thanks for clearing up my questions. My car won't be making anywhere close to 800 HP :lol:. I'll be picking one of these up in the near future.
Cheers,
Carthik
1988 BMW M3
1990 Honda Civic DX
1989 Yamaha YSR 80
2003 Derbi GPR 50 R
gaijin_rokurunner
Postby gaijin_rokurunner » Sun Jul 21, 2013 6:48 am
Cool let me know when ur ready
Jesse
Postby Jesse » Fri Aug 02, 2013 1:43 pm
I found the time to get mine in the car. Angles are obviously not yet set, will be shimming the transmission up a bit, and then adjusting the four links on the other end.
Bump for an awesome product!
gaijin_rokurunner
Postby gaijin_rokurunner » Fri Aug 02, 2013 6:49 pm
Awesome see your using the stock tranny mount...is it new i have a new trd one i will sell u i actually had some custom mounts made and wont be using the TRD one...txt me if interested u have my number...
overspool
Postby overspool » Mon Aug 12, 2013 8:10 am
How much do these driveshafts weigh? I just searched through the thread and couldn't find an answer, I could have skipped over it accidentally. Just curious what the reduction in rotational mass will be. Stock is ~22lbs.
gaijin_rokurunner
Postby gaijin_rokurunner » Mon Aug 12, 2013 8:56 am
Yes you missed it first post second paragraph 13.8lbs total weight
overspool
Postby overspool » Mon Aug 12, 2013 1:39 pm
herp derp. I knew I read it somewhere before, thanks dood.
gxdivider
Postby gxdivider » Mon Oct 21, 2013 4:26 pm
Hey are these still available? I need a carbon one for the Leen J160 kit. Thanks.
gaijin_rokurunner
Postby gaijin_rokurunner » Mon Oct 28, 2013 6:08 am
yes I can have one made for your LEEN...email me at nuffsaid02@aol.com
DrAE86Toreno
Postby DrAE86Toreno » Mon Oct 28, 2013 10:05 am
Aren't you overseas? Lol didn't I send you there? I'm in SD now lol
gaijin_rokurunner
Postby gaijin_rokurunner » Wed Oct 30, 2013 5:50 am
yeah im in afghanistan...since all u active duty sailors to scared to deploy lol....enjoy san diego hope they deploy you to gitmo for 15 months so by the time u get back to san diego its time to pcs lol
DrAE86Toreno
Postby DrAE86Toreno » Wed Oct 30, 2013 8:13 pm
Hahahahaha...hope ur doing good out there man I miss talkin bout cars at work! Lol hit me up if u need anything! I'll see if I still got some pull lol!
gaijin_rokurunner
Postby gaijin_rokurunner » Thu Oct 31, 2013 9:21 am
how about u replace me....ur active duty I'm a reservist yet your home and I'm dragging my nuts in the dirt every night when the rockets start flying!
DrAE86Toreno
Postby DrAE86Toreno » Thu Oct 31, 2013 3:50 pm
how bout i repalce your HM there and we can drag our nuts in the dirt together haha...anyways will my silly carbed 4AG need this super cool CF driveshaft? lol
gxdivider
Postby gxdivider » Fri Nov 01, 2013 8:21 pm
sent you an email rokurunner
phanist
Postby phanist » Tue Nov 05, 2013 5:33 pm
LOL Gaijin oversea but still doing business
crappy4ag
Postby crappy4ag » Sun Jan 05, 2014 2:56 pm
Still available?
Formerly "Levinpinas" est.'05
Follow me on IG: crappy4ag
gaijin_rokurunner
Postby gaijin_rokurunner » Tue Jan 14, 2014 1:01 am
Yes I can have this made and dropped shipped per order even from Afghanistan email me nuffsaid02@aol.com or message me if interested
phanist
Postby phanist » Wed Jan 15, 2014 2:44 am
gaijin
hope everything alright there man... i love the BT you help me built.....
thank you ....
i have one of this carbon fiber drive shaft... excellence piece.... have it on for about 6month now... all good people buy this .........
fitment is excellence same length as my stock gts shaft...
gaijin_rokurunner
Postby gaijin_rokurunner » Sat Jan 18, 2014 10:28 am
Awesome, glad the engine is up and running properly, have u dyno'd it yet? Remember don't be pulling other peoples cars with your built engine man....AE86 is not a tow truck lol
phanist
Postby phanist » Sat Jan 18, 2014 12:35 pm
Lol. Nah never again man....
I just need to tune my suspension for grip and dailly..... There is no place u can really try drifting in hawaii legally...
Take care man ... Later
Return to “Shops, Manufacturers, and Retailers Only”
