RPM Auto Parts-Toyota Corolla AE86 OEM Parts....and more.
rpmparts
Location: RPM Auto Parts 1113 Baker St Ste F Costa Mesa, CA 92626
Postby rpmparts » Fri Feb 08, 2013 9:40 pm
RPM Auto Parts AE86 Parts Inventory Availability list.
KOYO OEM Front Wheel bearing & Seals Set Left and Right sides
2 Outer Wheel Bearings koyo Made in Japan
$65.00 Free Shipping in U.S.A.
(For 1 side only Left or Right $35.00)
Performance Front and Rear Cross drilled and Slotted or Slotted only rotors set of 4 Gold Zinc Plated anti-corrosion
2 Front Performance rotors (Must chose Drilled and slotted or Slotted only)
2 Rear Performance rotors (Must chose Drilled and slotted or Slotted only)
$120.00 Free Shipping in U.S.A
Performance Front and Rear Cross drilled and Slotted or Slotted only rotors set of 4 Gold Zinc Plated anti-corrosion with PBR Brake Pads
1 Front set PBR brake Pads
1 Rear set PBR brake Pads
$165.00 Free Shipping in U.S.A
Toyota Corolla 4AGE 16V RPM Aisin Water Pump & Timing Belt kit
1 Aisin Water Pump
1 Mitsuboshi Timing Belt
1 Koyo Tensioner
2 THO Cam Seals
1 THO Crank Seal
$130.00 Free Shipping in U.S.A
Toyota Corolla 4AGE 16V RPM Aisin Water Pump & Timing Belt Gasket kit
1 Aisin Water Pump
1 Koyo Tensioner
2 THO Cam Seals
1 THO Crank Seal
1 KP/THO Valve Cover Gasket Set
$160.00 Free Shipping in U.S.A
Toyota Corolla 4AGE 16V RPM Aisin Water Pump & Timing Drive Belt Gasket kit
1 Aisin Water Pump
1 Koyo Tensioner
2 THO Cam Seals
1 THO Crank Seal
1 Bando/Mitsuboshi A/C Belt
1 Bando/Mitsuboshi P/S Belt
1 Bando/Mitsuboshi Alt Belt
$185.00 Free Shipping in U.S.A
THO Valve Cover Gasket Set 4AGE
1 THO Valve Cover Gasket Set 4AGE Made in Japan
$35.00 Free Shipping in U.S.A
Aisin OEM Clutch Master Cylinder AE86
1 Aisin Clutch Master Cylinder AE86 Made in Japan
$38.00 Free Shipping in U.S.A
Aisin OEM Clutch Slave Cylinder AE86
1 Aisin Clutch Slave Cylinder AE86 Made in Japan
$36.00 Free Shipping in U.S.A
1 Aisin Brake Master Cylinder AE86 Made in Japan
$89.00 Free Shipping in U.S.A
Taiho Engine Bearing Set 4AGE
1Taiho Main Bearing Set Made in Japan
1Taiho Rod Bearing Set Made in Japan
$85.00 Free Shipping in U.S.A
NPR Piston Ring Set 4AGE
1 NPR Piston Ring Set 4AGE STD. Size Made in Japan
$45.00 Free Shipping in U.S.A
AE86 Ball Joint (Aftermarket)
1 AE86 Ball Joint CTC/Parts Master
$22.00 Free Shipping in U.S.A
2 AE86 Ball Joints CTC/Parts Master
4AGE 20V Parts
Sprinter Trueno AE86 Front Grill Emblem
Sprinter Trueno AE86 Front Grill Emblem 75314‑12021 $85.00 Free shipping in U.S.A
KP Made in Japan Head Gasket Kit Engine Valve Grind Set
KP Made in Japan Head Gasket Kit Engine Valve Grind Set 04112-16330 / 0411216330 $245.00 +shipping in U.S.A (imported from Japan) only 5 available
Toyota Corolla Levin Sprinter Trueno AE86 Stripe GTV TWIN CAM 16 Sticker
Toyota Corolla Levin Sprinter Trueno AE86 Stripe GTV TWIN CAM 16 Sticker 75985-12380 / 7598512380 $110.00 pair (as shown) + shipping in U.S.A (imported from Japan) only 2 available
Toyota Corolla Levin Sprinter Trueno AE86 Stripe GTV TWIN CAM 16 Sticker 75985-12380 / 7598512380 $60.00 Each individual + shipping in U.S.A (imported from Japan) only 5 available
RPM Auto parts
1113 Baker St Ste F
Costa meas CA 92626
714-957-2741 7 Days
M-F 9-7 Weekends 10-5
All California residents must include 8% Ca Sales Tax on all orders made
Pay to: rpmpaypal@yahoo.com
rpmparts
Re: RPM Auto Parts-Toyota Corolla AE86 OEM Parts....and more
Postby rpmparts » Fri Feb 08, 2013 9:41 pm
Reserved for parts....... :D
RPM Auto parts
1113 Baker St Ste F
Costa meas CA 92626
714-957-2741 7 Days
rpmparts
Postby rpmparts » Fri Feb 08, 2013 9:42 pm
RPM Auto parts
1113 Baker St Ste F
Costa meas CA 92626
714-957-2741 7 Days
ronny
Postby ronny » Wed Feb 13, 2013 4:00 pm
it would be ultra amazing if you can put together a transmission rebuild kit together - with all bearings and what not.
Rays - Project Mu - TE37 club
BLUE MOON / CUSCO
AE86fightclub.com
PM me for Contact
rpmparts
Postby rpmparts » Thu Feb 14, 2013 12:20 am
We have one available and will update products here soon please call 714-957-2741
RPM Auto parts
1113 Baker St Ste F
Costa meas CA 92626
714-957-2741 7 Days
Postby MisterJerk » Mon Feb 25, 2013 3:54 pm
Front and Rear caliper rebuild kits? and front brake pads.
PM'd
Tang88
Postby Tang88 » Tue Mar 05, 2013 3:37 pm
How much for the transmission rebuild kit and could you give me a deal if i ordered more than one part.
Master and Slave clutch cylinder
Master brake cylinder
Wheel bearings
Transmission rebuild kit
Tekno Twinky
Postby Tekno Twinky » Thu Mar 07, 2013 3:40 pm
Hey guy do you still do the rebuild kits for ae86 differentials? carrier, crown wheel and pinion bearings, crush sleeve rear seal etc?
87Coupe_de_Ville
Postby 87Coupe_de_Ville » Mon Mar 11, 2013 1:29 am
Hey you guys have T50 gasket kit and SS clutch line in stock? If so pm me please.
1st place at Toyotafest 2012 and 2nd place at JCCS 2012.
The Robot Cow
Postby The Robot Cow » Thu Mar 21, 2013 11:10 pm
I want to get the asisn clutch slave and master cylinder.
Just waiting for my check to come in!
1985 Corolla Gts Coupe
brokuroku
Postby brokuroku » Sun Mar 24, 2013 7:02 pm
Interested in a timing belt, water pump gasket kit to 11358. Thank you.
previa19
Postby previa19 » Mon Mar 25, 2013 11:33 am
how long does shipping usually take for the rotor and brake package deal? shipping to oxnard 93036
previa19
Postby previa19 » Wed Apr 17, 2013 6:17 pm
The only way to order is over the phone or was there a website I missed?
Esenpai
Postby Esenpai » Mon Apr 22, 2013 11:23 pm
does wheel bearing kit only include the outers for $65??
I need both inner and outer I'm local and can pick up.
Esenpai
Postby Esenpai » Sat Apr 27, 2013 3:37 pm
Dropped by RPM Auto-parts today Its right by the Martial Arts gym I use to go to in Costa Mesa Cool guys GREAT prices would recommend to anyone in the South Orange County area.
Picked up their wheel bering kit which is both inner and outer bearings and they're Koyo bearings! the guud stuff mang!
steezedae
Postby steezedae » Mon May 20, 2013 4:52 pm
Do you still have the timing belt gasket kit for the 4Age in stock? The 160$ one
NeedHelpOnMy86
Postby NeedHelpOnMy86 » Tue Jul 09, 2013 11:05 pm
hey how do i pay you for the master clutch cylinder? thanks
Esenpai
Postby Esenpai » Sat Oct 12, 2013 11:23 pm
I lied. This place is run by a bunch of incompetent buffoons. The "4AG Master" here sold me a FWD water pump for my RWD 86 and the pulley mount snapped off slashing apart my brand new $350 KoyoRad Racing radiator that I literally put in my car the day before hadn't even gone 50 miles yet. also snapped the water pump and rear water pump housing They were "gracious" enough to give me the correct water pump but thats still $350 down the drain not to mention the costs of all new belts that are not contaminated with coolant and the coolant itself. All in all im out about $500. Will never do business there again and I advise you all to not either. Buy from amazon they're probably more likely to send you the right part
kendallspower
Postby kendallspower » Mon Oct 14, 2013 8:09 am
Agreed. I think they had some staff changes. They tried to sell me a "GTS" gas tank that was from a Nova/Corolla. "We sold tons of these". Lol.
Amazon isn't perfect either. I ordered a Tokico BMC and got a Sanyco.
Ya gotta watch fools.
hachirokufan
Postby hachirokufan » Sun Nov 03, 2013 9:38 am
That's why you check your parts before you receive them. At least I always do, since I've seen people get the wrong part at autozone.
RPM, can you put together a tune up kit for a 98 Nissan frontier xe with the ka24de?
dcal
Postby dcal » Mon Jan 27, 2014 8:40 am
Interested in the complete set of Front Wheel Bearings for my GTS Corolla shipped to 20011. Are they still available at $65.00? Can I pay through paypal? Let me know. Thanks!
YoShImUrA
Postby YoShImUrA » Wed Feb 26, 2014 12:29 am
Hello,
I'm looking for an AISIN brake master cylinder for an '89 MR2 (late or kouki AW11).
Also, will you ship to Europe?
TIA
Autobot1986
Postby Autobot1986 » Thu Apr 17, 2014 8:44 pm
pm you
SlideSexy
Postby SlideSexy » Wed May 28, 2014 1:04 pm
I'd like to order this i am paypal ready!
http://imageshack.us/a/img546/3208/ae86timingkit.png
ANYONE CAN BUY A NEW CAR. IT TAKES A TRUE ENTHUSIAST
TO BREATHE LIFE INTO AN OLDER ONE.
Esenpai
Postby Esenpai » Wed May 28, 2014 6:00 pm
SlideSexy wrote:I'd like to order this i am paypal ready!
Pretty sure they don't use c4ag at all.
also these guys sold me the wrong water pump when I bought this kit (I'm local to them) it pretty much blew up and ripped apart my brand new racing koyo rad that i put in with the timing belt when I did it. I made it about 50 miles before it went boom no more water pump no more radiator. and they were kind of assholes when I called them out on it but they did give me a new water pump and they "took my word for it" that I bought it there.didn't replace my radiator and they even charged me for the coolant I needed because of their f up. would suggest buying elsewhere.
SlideSexy
Postby SlideSexy » Wed May 28, 2014 10:56 pm
I called them and ordered. Later saw your post and didafollo w up call making sure they send a RWD pump. Im going to at it before i install. If its FWD theyll be getting another call with my complaint
