Brian Crower 7AGE rods group buy
Posted: Sun Jul 27, 2014 10:33 am
I have decided to go ahead with this. I have sent in a 7A rod and have already committed to buying 10 sets regardless of how many get in on the pre purchase. Since I don't want to put up all that money I will be offering a pre purchase discount.
The rods are approx 12 weeks out right now so if you order before before November 1st I will do them for $440. After that they will be around $460
This rod is being made by Brian Crower specifically for Matrix Garage. It is also made specifically for 7AGE builds. Unlike the 7AFE rod it will have a floating wrist pin identical to the 4AGE. This means you will be able to run 4AGE pistons or order aftermarket pistons with floating wrist pins.
This does mean that these rods will not work with stock unmodified 7AFE pistons.
These rods will be equivelent to the Brian Crower Sportsman rods for the 4AGE. They will come with ARP 2000 hardware.
http://www.briancrower.com/makes/toyota/4age_rods.shtml
This is a pre buy. The rods will be available around the first of November. The price will be discounted during the pre buy and will be marked up to $460 as soon as they hit our shelfs. Order them now and save $20.
These are designed to work with floating wrist pins like all 20mm 4AGE pistons. These will not work with stock 7A pistons without modification. If you want to use these rods on a 7AFE or with 7AFE pistons it will be up to you to work out your own solution for pistons.
We can get you custom pistons that will work with these rods.
http://www.matrixgarage.com/products/brian-crower-7age-h-beam-rods-pre-buy
