Specs are below....
Initial D Panda Scheme Body
1:10 Scale
4-wheel drive system
Oil-filled shocks
High performance motor
High precision ESC
Extra large front bumper foam
Extra long body post
Durable on road drifting tires with embedded small sparking stones and chrome plated spoke rim
Front turning linkage set
Anodized aluminum motor heat sink
Built-in AM receiver
Working headlights and tail lights
Can go up to 18 miles per hour (30 km/h)
Includes NiMH rechargeable battery and 2.4 GHz remote control
Battery Specifications:
NiMH battery type
2000mAh
7.2V
Specifications:
Wheel base dimensions: 9.84-inches (250 mm)
Wheel diameter: 2.55-inches (65 mm)
Wheel Width: 0.98-inches (25 mm)
Tread (F/R): 195 mm
Gear ratio: 1:8.7
Remote Features:
Steering Wheel
Trigger
Steering Trim
Steering Reverse
Power Switch
Steering Dual Rate
Throttle Trim
Throttle Reverse
Bind (Pair Button)
Red and Green LEDs
Powered by three (3) AA batteries (not included)
Car Dimensions:
Overall: 5.11 x 7.4 x 18.1-inches (H x W x D, approximate)
