Complete set of Epsilon mesh. Assembly and work required however. No tires.
Specs:
ALL made from 548 hoops
Since this set was made from all rear hoops, there is no drop center. So to mount and dismount tires you can't use a conventional tire machine. You would also need a "cheetah" to seat the beads. As long as you assemble them correctly and use the right silicone, you won't have leaks.
Four 15x9.5 -27 4x114.3 (gray and black faces) Two are completely put together, the other pair needs to be assembled.
All four faces Need center bores to be welded along hairline stress fractures.
Only ONE rear hoop needs to be SLIGHTLY straightened along the outer flange. Honestly it's nothing major.
pic of hairline fracture
