3tc clutch $300
3tc clutch $300
i have a stock flywheel, a fidanza fly wheel, and act clutch pressure plate and a 4 puck sprung disk for sale for a 3tc motor. will also work for 2tg and other toyota motors with the same flywheel bolt pattern.
to safely wreck a car, you must first be safe.
Re: 3tc clutch $300
how much for the fidanza fly wheel
Re: 3tc clutch $300
Friction surface of the fidanza is 215mm. Friction surface of the stock wheel is 225mm. The unsprung disk is 225mm, the sprung 4 puck is 200mm.
Re: 3tc clutch $300
How much for the Pressure plate "ACT" 200mm or 225mm?
Re: 3tc clutch $300
nocturnalmiracle wrote:i have a stock flywheel, a fidanza fly wheel, and act clutch pressure plate and a 4 puck sprung disk for sale for a 3tc motor. will also work for 2tg and other toyota motors with the same flywheel bolt pattern.
is this still available? if so where are you located
Re: 3tc clutch $300
Just to let all of you know I have a 3tc engine for sale for $350 so if you want it it's yours! Located in SoCal
viewtopic.php?f=15&t=11404
