Just gauging interest since I might part out. This has a lot of custom work going on to make it FR layout and stay together. I've only ever run full synthetic in it. Never had a thermal event or low oil pressure.
Engine. used ST215 engine. Comp 190 across the board.
New parts with less than 1000 miles:
toyota timing and water pump
cam, oil pump, and crank seals
panicwire engine harness
link g4 storm ecu
custom intake manifold w/ nissan throttle body by xcessive
custom turbo manifold and dp by xcessive
custom cooling system by xcessive
custom oil return from head by xcessive
blacktop beams oil system
j160 transmission (perfect shifting)
OS giken super single alum cover
borgwarner EFR 6258 turbo
326whp/262wtq@15psi.
Looking for $6000
This shouldn't be much trouble bolting in place of a blacktop beams since all the relevant dimensions are the same except the rear cooling neck.
Thanks,
